Wow! Nice.When are you coming to teach me how to sail my boat as I never got a chance for you to sail it with me?.
All Bill offered to teach me was how to drink copious amounts of rum and still be able to read a compass.
I use the plastic tube to check the ballast level when draining the ballast whne under power going 6 MPH, use it like a staw (finger over hole) to ensure the ballast is empty. Hope that makes sense.DLT wrote:Albion,
My boat came with a rigid clear plastic tube, which I presume was for checking ballast. I've never used it, and don't see why you'd need to.
When my tank is full, there is water in the dam under the vee berth. I just don't put the plug in until I see water there...
Good to hear the problem is identified, Leon, even if the final solution is still pending!delevi wrote: . . . The front hatch wasn’t closed tightly. Felt like a real dumbassConsequently, I discover that I had a broken rubber seal as well, which I proceeded to fix with silicone. I did order a new one, however. After shutting hatch tight, I noticed that all the tension is just in the middle part. I always assumed that it was ok, but I decided to push up on the front corners to test it. I could literally lift either of the forward corners by hand from the inside and create a gap an inch or two wide. While I replace the rubber seal, I’m thinking to replace the locking mechanism. I don’t like what’s currently there… a tension bolt style lock. I’m thinking to install two small clamps on either side. . . .
I'm thinking of using a clamp... hard to describe what I'm picturing here....something like for the top of a shop vac but larger or the type used to hold the top and bottom of a dog crate. One end fits into the other... approx 4 inches wide, then you pull the movable piece which is on a swivel axis and it clicks in place. Would be much nicer than the factory bolt... POSI've pondered getting an improved latching system
I've also considered a similar latch - I hate the one that came with the Mac.delevi wrote:I'm thinking of using a clamp... hard to describe what I'm picturing here....something like for the top of a shop vac but larger or the type used to hold the top and bottom of a dog crate. One end fits into the other... approx 4 inches wide, then you pull the movable piece which is on a swivel axis and it clicks in place. Would be much nicer than the factory bolt... POSI've pondered getting an improved latching system
Yeah, but two drawbacks... first, I think it's too short... and second, I *know* I'd smack my head on that dang thing!delevi wrote:Thanks Kevin. I like the one in the fourth link you posted, the bronze looking one.
They also sell the nasty bugger that's on there from the factory:DRAW-CLAMP LATCH
Center tensioning device ideal for hatches, doors, cabinets, or wherever a tensioning device is needed. Finished in Polished Brass and Polished Chrome (over Brass). Fasteners not included.
US$17.95 / EACH
Locked Length: 3-5/16" Open Length: 2-11/16" Width: 1-5/8" Fastener Size: #8 Weight: 4 oz. P/N: 350010 (brass) / 350011 (chrome)
HATCH DOG
Ideal for sliding companionway hatches. Includes catch. Black bakelite knob easily secures hatch. Finished in Polished Stainless Steel. Fasteners not included.
US$10.95 / EACH - STAMPED STAINLESS STEEL
Base Diameter: 1-1/2" x 5/8" Fastener Size: #8 Weight: 0.15 lbs. P/N: 350177
