Agree with Chip. While the alternate day (Odd/Even) has logic, for my situation with two WEST MARINE SeaVolt Dual-Purpose 12 V Batteries, I change the multi connection house wiring terminal fixture at the start of the season to the other Dual-Purpose battery. I try to forget what day of the week it is much less, if the day is odd or even,Chip Hindes wrote:I have been using a different methocd of alternating two identical deep cycle batteries, charged through the now relatively standard three switch system using a voltgage sensitive relay.
I switch the batteries from house to starting duty each year.
Use two 5 Watt rated solar panels to keep them trickled charged up. Have Nano-pulsers on each to keep the plates from getting a build up of lead-sufate crystals on them and thereby get long life from them http://www.pulsegenetech.co.jp/en/what/index.html. Switch to both batteries after starting motor and warm up.
