Mast light won't work
Post by Frank C »
tangentair wrote: . . . may have given bad advice. I did not consider that solder and copper are dissimilar metals and electrolysis may occur in this case. At least this was the case in an article I was reading ...
IIRC ... the prevailing wisdom says no solder on boats. Not sure if the reason is electrolysis, or just vibration. It might be an ABYC recommendation(?), but I think I've read that they call for tinned wire, coated, then crimped, and finally shrink-wrapped.
However, I saw a nifty Bernzomatic butane torch at the Depot last week. I think it's called a micro-torch. The little case included a "hot-knife." Said to self, "gotta have!" I was thinking it would be nice for cutting & dressing rope.
NOT ... can't get it hot enough to cut rope, half-inch diam. :x
