Lots of great advice here for those new to launching a Mac. I have thoroughly enjoyed learning this art form from zero experience to "pretty nifty" imho
However, the truth is, most time is spent doing all the little bits! My list would be something like this:-
Pay the man at the dock, fill in his forms!
Make a cup of tea.
Remove towing tail board and electrics, trailering tie downs, nylon ties on shroud wire, bungees on rudders and securing pin in rudders, securing straps holding roller furler to boom.
Raise mast using all known techniques - Easy! Raising kit with quick release pin and shackles, baby stays with quick release shackles, drop lifelines using quick release pelicans to ease mast movement (avoid falling off deck onto concrete 6ft below)
During mast raising, I push the mast well back and hang it down the stern of the boat suspended on the babystays at the front. I can then reach the top of the mast from the ground to fit the Windex (Only about three minutes but should I bother - would the Windex be OK left on with say 50mph force pushing upwards on it?)
I use the method of just overtightening the forestay to pin the furler to the deck - works great. I always, always cleat the raising line properly with a figure of eight when leaving the winch to move shrouds about and when going forward to insert the pin. I also use the left leg of an old pair of Levis as a bag to cover the drum whilst it squirms round the deck during the lifting process (Wranglers would probably suffice but please don't be tempted to use cheap Chinese imports)
I prefer to use bolt and nut on mast base (speedy ratchet spanner -looks very professional and makes a great clicking noise)
Fit VHF and mast lighting deck connectors
Fit adjustable back stay with micro blocks for easy fitting
Say to oneself "must do all tasks nearest to hand and avoid walking up and down this boat even though it is a lovely boat to walk up and down on"
Fit boom - I prefer bolts and nuts - more lovely clicking noise. Boom has mainsail ready fitted in a bag with lazy jacks (6 lines all attached with quick release clips). Insert sail slugs - quick pin in mast to close gate
Fit vang with quick release shackles
I've towed with the foresail left furled on the plastic foil and also tried it without. Obviously another 5 - 10 minutes to raise the foresail and then furl it, if stowed separately (idea - must fit a little quick release shackle to the furler halyard where it connects to the drum instead of needing to use a shackle key or pliers)
Getting there... methinks it's time for another cup of tea.
Fit spray hood - all ready fitted to SS frame - 5 mins to fit into position and secure
All lines through spray hood to cockpit
Fit cockpit tent. SS frame in place, canvas needs fitting and zipping to SS frame in 2 places - single handed? Yes, it's easy. I work from inside/underneath whilst the tourists and "dock salts" have a good laugh from the outside.
Fit wind powered generator. Already fitted to extension pole - just slot the extension pole into base pole and connect quick electric connectors inside the two poles whilst holding the damned things as near as possible with one waving around in the air. This usually draws the biggest crowd because it is done up on the coaming (knees wedged against pushpit).
Fit cockpit cushions
Definitely getting near now - no need to stop for tea - keep going, keep going
Get gear from trunk of car (bacon, sausages, etc, beer, fishing rods etc -
slight looks of envy now replace the hilarity in the audience).
The rest we all know - ballast valve, fenders, dock lines, fuel, engine procedures, fresh water, dunk the whole thing in the water (is that a touch of hostility emerging in the crowd as she floats without mishap??), wash down trailer if needed and park it using all sorts of insurance compliant locks and things, race back to boat and.........
........Go Sailing
Time taken - no idea. Benefits enjoyed - immeasurable
Sorry for the long post - I got carried away - I think it's the long cold nights.
Mike
