Page 11 of 21
Re: Yet Another Galley Mod
Posted: Wed Sep 23, 2020 3:03 pm
by Jimmyt
Well, it's Wednesday afternoon and the varathane is still not hard, So, I went to the Lowes further from urban centers and got some minwax Helmsman spar urethane. I put the random orbital sander to the droopy sides and ground most of it off. Actually, it just rolled it up. No dust at all
Wiped on a layer of Helmsman and the stuff is already dry to the touch. So, a bit more sanding and varnishing before I can mount the fiddles, but at least the pace is picking up.
Posted: Fri Sep 25, 2020 12:48 pm
by Jimmyt
Finally got the fiddles mounted. Titebond ultimate on the wood-wood joints, and 100% silicone adhesive between the laminate and wood. Finish nails, and brads on the front and ends, screws in back.
I masked off the laminate to control the squeeze-out.
I'll round off the front corners where we'll be running into them, and probably the back corners, too. A little sanding, varnishing, and nail filling, then screw the back cover on, and toss it in.
Looking forward to getting it done.
Posted: Fri Sep 25, 2020 9:23 pm
by K9Kampers
Posted: Sat Sep 26, 2020 12:30 pm
by Jimmyt
Not sure I want to know how many hours I have in it.
The labor is the big cost in something like this. I don't think materials went north of $500 (about $175 of which was sink).
I think we need to wait and see if BOAT's prediction of capsize at first launch comes true.
Nothing kills envy like a total disaster.
I'm about ready to be finished with it, but I have enjoyed building it. It's the first thing I've done just because I wanted to do it, since I retired. Hope folks were entertained by the sausage-making.
I'm getting ahead of myself, though... It's not in the boat yet!
Posted: Sun Sep 27, 2020 6:08 am
Can't wait to see it in the boat.
Macs sure could use some wood. I'm disappointed Roger took away the wood trim on the windows.
Posted: Sun Sep 27, 2020 11:15 am
by Wayne nicol
a true work of art!
very well done!!!!
Posted: Sun Sep 27, 2020 12:12 pm
by Jimmyt
Wayne nicol wrote: ↑Sun Sep 27, 2020 11:15 am
a true work of art!
very well done!!!!
Thanks! Now, if I can round up a few friends in the next couple of days, we can call this part done.
Posted: Mon Sep 28, 2020 1:59 pm
by Jimmyt
kurz wrote: ↑Mon Sep 14, 2020 3:37 am
When your are finished could you weight it without the stove? Would be interesting!
Didn't weigh it without the stove, but the stove and gimbal just weigh a few pounds. The complete galley is 173.2 lbs. Maybe BOAT was right. Capsize may be imminent.
Stock sliding galley is 28 lbs.
I'll be interested to see how the boat handles it.
Posted: Mon Sep 28, 2020 3:23 pm
by K9Kampers
Next project... fridge/cooler, wine /spirits , humidor custom cabinets on the starboard side for, you know... counterbalance!
Posted: Mon Sep 28, 2020 4:02 pm
by Jimmyt
Posted: Tue Sep 29, 2020 5:22 pm
by Jimmyt
Posted: Tue Sep 29, 2020 5:26 pm
by Jimmyt
Posted: Tue Sep 29, 2020 5:36 pm
by K9Kampers
Woo hoo!!
And you didn't even have to slather it with mayonnaise to send it thru the companionway!
Posted: Tue Sep 29, 2020 5:42 pm
by Jimmyt
K9Kampers wrote: ↑Tue Sep 29, 2020 5:36 pm
Woo hoo!!
There was a moment, before we figured out to put the throttle at full reverse and move the mast over, when we probably would have slathered it with mayo if it was nearby!
Posted: Wed Oct 07, 2020 4:04 pm
by Jimmyt
Hooked up the drain line and tested it this evening. Failed
The plastic body of the lower portion has a threaded center that you screw a hollow stainless fastener into, holding the stainless portion inside the sink to the plastic portion under the sink, and theoretically compressing the rubber seal to the underside (or not - in this case). Going to have to use plumbers putty or some other sealant. Surprisingly, the hose connection to my hand-ground PVC nipple didn't leak a drop. Used a heat gun on the hose to soften it a tad so I could jam it on good.
Still mulling over the pressure water system design.
