Page 13 of 19
Re: Southport Sail
Posted: Thu Mar 12, 2015 10:25 am
by fishheadbarandgrill
My float plan is to float from village to village sampling the local offerings...
Victor told me has coming was long as he could finish the supercharger install on his Suzuki 90. :o :o
Re: Southport Sail
Posted: Thu Mar 12, 2015 8:37 pm
by cptron
fishheadbarandgrill wrote:Victor told me has coming was long as he could finish the supercharger install on his Suzuki 90.
I guess he is turning into Tim Taylor "MORE POWER". :P :D :D
:idea:I wonder if they make a jet engine light enough for the Mac. :wink:
Re: Southport Sail
Posted: Thu Mar 26, 2015 5:55 am
Out of curiosity, what's the insect situation like in Southport and vicinity at that time, and through late May or early June?
Re: Southport Sail
Posted: Thu Mar 26, 2015 8:02 am
I don't remember it being a problem... But then again, I'm from Charleston so it's got to be pretty bad for me to consider it bad... if anything we might encounter biting gnats otherwise known as flying teeth or "No See'ums". They are only out when there is no wind during the early morning or late afternoon.
Bob
Re: Southport Sail
Posted: Sun Apr 05, 2015 8:17 am
Just made my reservations at the Southport Marina for Friday night and the Wilmington Docks for Saturday night. The dock master at the Wilmington Docks knew about the group but didn't know who had called in their reservations (The big boss has that info). I mentioned the McGregor group when I called the Southport Marina as well. They didn't have anything noted about a group but I got the feeling that the guy that took may not have known about the group coming in anyways....
So if you haven't made the call to Wilmington or Southport, I suggest that you do as soon as you can. Neither required a CC to reserve.
See everyone in about a month... looking forward to seeing Admiral Cindy without a cast.. :o :o
Bob and Lynn
Re: Southport Sail Dock Reservations!
Posted: Sun Apr 05, 2015 8:31 am
by vkmaynard
Just talked with Cindy Brown about reservations.
If you are going you need to call and confirm both Southport Marina (910-457-9900) on May 8 and Wilmington City Docks (910-520-6875) on May 9.
Several of us called just now.
Victor
Re: Southport Sail
Posted: Sun Apr 05, 2015 8:56 am
by wbpenney
Just called Southport and Wilimington. We are good for The 8th and 9th.
Re: Southport Sail
Posted: Sun Apr 05, 2015 9:18 am
by wbpenney
Also check and see if the power available at Wilmington City Docks is 30 or 50 amp. If they put you in a 50 amp area,you will need an adapter. We had issues with this before.
Re: Southport Sail
Posted: Sun Apr 05, 2015 11:36 am
by Gabby_SC
Reservations made, sounds like quite a few are calling today
Re: Southport Sail
Posted: Sun Apr 05, 2015 1:40 pm
by SENCMac26x
I'm good to go, had already called Wilmington just called Southport.
See you guys then!
Re: Southport Sail
Posted: Sun Apr 05, 2015 7:07 pm
by SENCMac26x
Just in case they run out of 30amp spots, will this adapter suffice?
For $14.97 I think I'll get one to have just in case. (If a marine 50amp is the same as an RV 50amp hook up)
http://mobile.walmart.com/find-in-store ... 35/-77.856
Re: Southport Sail
Posted: Sun Apr 05, 2015 7:43 pm
by cptron
Sounds like we are going to have a great turn out. So far there are 11 boats that I know of. 8)
If you haven't done so, call in your reservations at Southport Marina for May 8th, (910-457-9900) and Wilmington docks for May 9th, (910-520-6875).
We still have room for more if anyone wants to join. Come on everyone lets take Southport by Macstorm. :P
Cpt. Ron & Admiral Cindy
s/v Storm Walker
Re: Southport Sail
Posted: Mon Apr 06, 2015 5:22 am
SENCMac26x wrote:Just in case they run out of 30amp spots, will this adapter suffice?
No, RV receptacles are different (NEMA TT-30 I believe). Marine uses twist-lock plugs and receptacles, with the NEMA L5-30 configuration being 30A single-phase 125V (rated), grounded ("L" is locking, "5" is 125V rated, "30" is 30A rated). There is no NEMA standard for an L5-50 (it's not even called that, but I don't recall what it is), and it's basically the same thing in a 50A configuration, but incompatible with an L5-30 receptacle.
And there's also a 50A 125/250V marine configuration, which is incompatible with a 50A 125V plug.
So you'd need a real adapter, of the correct configuration, which is something like $150 I'm afraid. Might be better to use a very long 30A cord from another power pedestal, alone or as an extension, if needed. A 50 footer is around $90 from WM. Maybe cheaper elsewhere.
Re: Southport Sail
Posted: Mon Apr 06, 2015 8:35 am
by vkmaynard
Posted this for the last Southport Sail.
Bill Penny adapter find, super low cost at $40 shipped (now $43 plus maybe shipping). http://elecordset.com/moreinfo.aspx?pid ... .aspx&ai=M
We bought four sets last year. All worked great.
Victor
Re: Southport Sail
Posted: Mon Apr 06, 2015 9:26 am
vkmaynard wrote:Posted this for the last Southport Sail.
Victor
four sets... that's one big blender!! :D :D
