Re: Tacking in high winds
Posted: Fri Mar 24, 2017 4:44 pm
France 16 has more than just a reef in - he is on a storm jib - he is not even using his genoa - it's fully furled. He is in a blow - very heavy wind and he is still near knock down -
Alex Thompson (Hugo Boss) reefed for the Keel walk, but on the mast walk the sail goes all the way to the top (no reef) because he needed to heel over further for the mast walk than he did for the keel walk. They also had to remove one of the rudders for the keel walk so Thompson would not get ripped in half when he fell off the keel.
None of the other boats are reefed, and in fact Wild Oats is doing exactly what mike said they were doing that resulted in their crash - he is sailing with NO reef, PLUS a Genoa, AND ANOTHER HEADSAIL! IN A BLOW! There are a lot of pilots that would rather hang people off the side than reef - Wild Oats skipper is one of them - that's why he wins so many races.
I can tell you that in a lot of these instances I WOULD REEF! ESPECIALLY in the situation Wild Oats is in. But none of the boats that are racing have a reef in except number 16.
The single handed IMOCA boats do indeed reef all the time - and for the very reasons cited: SAFETY - when your all alone you do not want to break the boat.
I am not on any "side" - as far as debating anything I can't really debate an X boat driver on this because it's not the same boat as the M boat - the skipper needs to make his own choice - all I am saying is that I do not get all panicked about SAILING on my "side" - it's just not one of those things we need to be overly concerned about, (at least on the M boat it's just not a big deal). Don't risk your life on deck trying to reef the main just because the wind goes to 12 knots or your heel angle is over 40 degrees - it's a lot safer to just ride out a gust of wind at 45 degrees than it is to risk your life trying to reef the main on a steep deck. Just relax and let it pass - if it's a big problem then furl in the Genoa first. The M boat sails REALLY GOOD on just the main alone - Roger said so many times and it's true.
The last picture believe it or not is the boat in the most danger - and it's also the boat sailing the flattest on the water. The last picture is the HUGO BOSS 99 going downwind on a spinnaker at blazing speed in heavy wind - he has the daggerboards up and the hull way further out of the water than what it is on a reach or a run - you can tell because the boat is DRY - all the boats on their sides are WET (they are IN the water like a submarine) The reason the DRY boat going downwind on a spinnaker is SO dangerous is because if the wind suddenly shifted to the beam tha boat would capsize in an instant if the helmsman does not turn the boat back down the wind - the kite will pull the boat right over if he does not turn immediately with the sail - and that's why the skipper in that picture is on the helm with his eyes on his kite.
If I really was a wild man kites would not scare me so much - but I have seen them pull boats right over on their sides - they scare me. I think the stock MAC kite is probably small enough to protect your boat but if the wind is blowing hard I myself would not risk one. One time I saw a kite actually drag a boat through the water on it's side in a bad blow - the crew was desperately trying to cut the kite loose as they were being dragged.
