Page 3 of 4
Re: Solar panel to recharge 2 batteries
Posted: Wed Mar 31, 2010 6:09 am
by March
It is a 1500 watt Sunsei with a charge controller
Are you sure it's 1500 W?
Posted: Wed Mar 31, 2010 6:45 am
by elvatoli
Does anybody knows if for the 26X, you can make an arch type support, like the mast support on the M, to mount a 100W solar panel that is 52 in x 30 in ?.
If I make that it will help me to have more things than the solar panel, a flag, etc. But I dont know if I have to make two big holes somewhere on the transom or perforate holes for bolts and nuts.
Thank you
Hector
RGV, Tx
Posted: Wed Mar 31, 2010 6:47 am
by Kelly Hanson East
Sure - its a 1500 Towable Solar Array...
(Im guessing its 150W)
Posted: Wed Mar 31, 2010 7:46 am
by dvideohd
roughly 7 1/2 average, full size panels....
Two 60's might be better... or a full size 180W (180-22W).
-jr
Posted: Wed Mar 31, 2010 8:48 am
Posted: Wed Mar 31, 2010 9:49 am
by Hamin' X
Here is what I use to maintain my batteries (2 golf-cart 6v for house and one group 24 marine for starting with West Marine isolator:
BatteryMINDer® Solar Charger Controller 12 Volt with 15 Watt Panel
The Desulfator stage sends high frequency micro pulses that force to sulphation on the plates back into solution, obviating the need for cycling the batteries. Works great laying flat on the cockpit seats and even with heavy overcast. It is not meant to recharge drained batteries, rather just maintain a charged, or nearly so system that is in good health. The combiner, controller and monitor, reside in the space aft of the galley with the starter battery. The house batteries live under the forward dinette seat. The solar panel has a nifty place in the head for storage when not in use. I'll try and get some pics up later today.
Posted: Wed Mar 31, 2010 10:07 am
by c130king
Rich,
I think that may be exactly what I am looking for. Does it hook to each of your batteries simultaneously or do you hook to one and jump or combine to the others?
Posted: Wed Mar 31, 2010 10:10 am
by Hamin' X
It connects to the starter battery and the combiner shunts the charge to the house batteries. This allows the house batteries to be drawn down, without discharging the starter battery. All solid state and automatic.
Posted: Wed Mar 31, 2010 10:27 am
by c130king
Thanks. I will read over the specs a little closer and give it a thought.
Posted: Wed Mar 31, 2010 2:06 pm
by DaveB
Hector,
I have been trying to get Dingy Davits that will also have a platform for a 85-100 watt solar panel and may just have a local Aluminum welder do it. I think it would be much less expensive than the $1200-1800 I have seen.
Also want to put VHF and FM Antinas on the Frame but fold down for tow.
If I can't get access for bolts thru exsisting vinyle cap covers than will make new holes. I already have diffrent size plastic plugs I bought thru BWY.
elvatoli wrote:Does anybody knows if for the 26X, you can make an arch type support, like the mast support on the M, to mount a 100W solar panel that is 52 in x 30 in ?.
Thank you
Hector
RGV, Tx
Pics of Solar Battery Maintainer
Posted: Wed Mar 31, 2010 4:18 pm
by Hamin' X
Panel's travel home in the head. Hold down made from ABS plastic pipe, carriage bolt and wing-nut. Plastic strip screwed to floor, to prevent panel from kicking out:
Controller/Conditioner on left. Monitor on right. Quick disconnect at top. Combiner is out of sight to the right. This is the starter battery in aft galley seat storage, house batteries are forward.
Panel in cockpit.
Posted: Wed Mar 31, 2010 6:21 pm
by Bobby T.-26X #4767
Thank you
Hector
RGV, Tx
PM me off-line and I'll send you info, pics & specs.
Bob T.
"DāBob"
Dinghy Motor: '06 2.5-Suzuki
Posted: Wed Mar 31, 2010 10:00 pm
by School House Steve
OK My bad. :cry:
It is Solarcharger SE-1500.
Instructions are in French so some misunderstanding. :?
DESCRIUPTION DU PRODUIT
SolarCharger 1500: Chargeur D'entreien de batterie A Energie solaire 1500mA, 15V (22.5W)
I think it puts out about 1.5 amps per hour. :)
Steve
Posted: Sun Apr 04, 2010 11:34 am
by elvatoli
It is possible that my 5 W harbor freight panel is actually draining my battery instead of charging a little bit ?
Yesterday I took a measure during daulight of the panel terminals with my voltmeter and the reading was -.015.
Ideas ?
thank you
Hector
RGV, TX
Posted: Sun Apr 04, 2010 12:13 pm
by Hamin' X
Solar panels can discharge batteries, if they don't have blocking diodes installed. Most charge controllers take care of this function and most higher end panels have them included. I am not familiar with the HF ones, so I cannot be more specific.
