Page 3 of 3
Re: top speed Honda 50Hp
Posted: Wed May 25, 2011 6:18 pm
by magnetic
@Dave
magnetic wrote: previously
To my mind the BF50 is a truly awful engine; firstly, it is identical to the BF40 except for the ignition mapping software, which means that for most of the rev range you get the torque and general grunt associated with a far smaller engine. Secondly the cav plate and rudder skeg seriously restricts the diameter propellor you can select, and I am a firm believer in blade surface area over pitch.
Posted: Wed Jun 08, 2011 10:09 am
by Andre Emmenegger
17 knots. WOT, with stock Honda 4 Blade prop.
Posted: Thu Jun 09, 2011 10:16 pm
by Phil M
Andre Emmenegger wrote:17 knots. WOT, with stock Honda 4 Blade prop.
No ballast? One person? Calm? at sea level?
Or were you surfing down a big wave? :D
Phil M :macm:
Posted: Thu Jun 09, 2011 10:30 pm
by magnetic
17 knots is more or less where I got to in 2010 - flat water, minimal wind or tide, ballast out, 1 person, full tanks, mast & sails in position, antifouling paint, standard kit below decks
My :macm: swings a 3-blade Honda prop, dimensions listed elsewhere in this discussion, and these days I max out (at sea) at around 16 knots WOT / 6,000 rpm. It may well be the case that the 4 blade is a better prop
Posted: Fri Jun 10, 2011 11:32 am
by Andre Emmenegger
17 knots WOT, sea level, one person, light load, calm seas, no tide, no wind, stock honda 4 blade prop. I only longboard, so no surfing this time.
Posted: Sat Jun 11, 2011 1:13 am
by Gypsy
2000 26X with bottom paint , loaded with gear and water.
Honda 50 engine with standard prop
All sailing gear and full ballast
two people on board
We get about 10mph .
I tried a high speed run just the other day , same as last year , about 10mph max. :macx:
Posted: Sat Jun 11, 2011 12:05 pm
by Andre Emmenegger
You have to empty the ballast to go faster.
Posted: Sat Jun 11, 2011 1:11 pm
by Gypsy
I didn't buy a Mac to go fast . I bought it because it carries enough motor to get out of the way of a storm and it has an alternator .
I can cruise at hull speed and get close to 10mpg or sail and ride for free .
Which beats my previous boat , a 22' Bayliner cabin cruiser that got 3 mpg at hull speed .
I bought a :macx: to use as a poor mans trawler with the option of sailing.
For me to need to run so fast as to dump the ballast , I would have to be rushing somebody to a hospital .
Posted: Sat Jun 11, 2011 1:50 pm
by magnetic
I agree; as I said in my earlier comment,
The longer I have had the :macm: the less concerned I am about outright speed under power; sure, 10 - 12 kts to get the boat up out of the water around 4,500 revs, but above that the fuel economy really drops off badly; I would far prefer to have a massive prop which could consistently smash me through lumpy seas at high displacement speeds, but the Honda isn't able to swing one :?
