Sounds like you and I are at about the same point. Are you using a barrier coat? What Anti-foul did you choose?Dougiestyle wrote: ↑Sat Apr 18, 2020 12:44 pm I got my CB out relatively simple (it just needed a little extra persuasion). I should be finished sanding the bottom of my boat today. I might have good temps by the end of this week for paint. Will post photos later.
The interprotect 2000E seems to be doing a very good job filling the scratches and dings. I had one deep scratch that penetrated the old barrier coat and dug deeply into the gel coat below. I mix up small batches of 2000E and put a couple of extra layers on with a small paintbrush, and most of them are almost gone. I used the small paintbrush technique to do the edge of the centerboard trunk but I didn't touch whatever was up inside there.
First coat done:
The old 2000E barrier coat is still mostly intact, only sanded it off in a few places, so most of the bottom will end up with a very thick coating. I think I am going to do three coats: two grey and the top one white. It takes just under a gallon of 2000E to do one coat.
Here is the scratch, sanded level. I think it will be completely gone after the next coat.
