The surge brakes have behaved nicely and take most of the trailer/boat deceleration loads.
We stay within our factory 3500 lb tow recommendation and 350 lb tongue weight and GVWR.
From the get go we added towing snubbers to the rear axle and properly rated and inflated tires on the van and trailer.
We limit our speed to 55 MPG as we aren’t in a hurry and desire to minimize wear and tear for the long haul.
We avoid steep slimy ramps and ramps with gravel. (Front wheel drive tends to dig in.)
The Caravan and trailer combination behave very nicely on the highway and we appreciate the 20+ mpg fuel consumption.
BUT we also carry tread plates just in case as well as 100 feet of 1” diameter twisted nylon low stretch rope and a 2000lb capacity come along ... been doing that since High School and it has been helpful in helping others as well as ourselves innumerable times over the years..
We have traveled from NH to SC without any incident and plan on doing this loop twice a year using Over Easy as a camper enroute like we did traveling down last November. A small 1000 watt 110 VAC heater more than adequately took care of keeping us warm in the campgrounds. Good sleeping bag quilts made for a comfortable night’s sleep when stopping at rest areas.
While we guess some like to travel with more stuff we don’t quite understand some of the high weights mentioned but to each their own. In our travel planning we recognize that things like fuel, water and other supplies can be had at or near launch
We also understand that this approach does not apply to everyone and their travel plans. We don’t expect it to.
We just wanted to convey that it is safe and doable to happily travel within the 3500 lb tow limit and 350 lb tongue and GVWR envelope over distance as long as one is reasonable about the process.
