Sheppie
Here,s how my boat is rigged for 4 furling sails hope this helps u understand the rigging process a little better
So u seem to b jumping back & forth between Code Zeros , Generators/ Drifters & Gennaker & Spinnakers !
Think of Code Zero as a 165% to 185% flat cut Genny either 3/4 or 1.5Oz spinnaker cloth ur choice I,d opt for the 1.5Oz stronger more durable will last longer and u will b able to keep it up longer as the winds get stronger to a certain point , the flatter the code O the more u should b able to point into the wind if u get one with more depth "less flatter" u will lose some of that upwind ability .
Now think of the Generator as the same cut and shape as ur Genny but instead of 5oz or heavier sail cloth it can b 3/4oz or 1.5oz great for light winds where as ur genny 5oz would b just flapping if the wind is not strong enough to fill it
now these two sails can b flown free if u want to use a shoot scoop but with a straight luff can b used with a Code 0 bottom up Furler
Where as Gennakers & Spinnakers can b any size size from 250sq ft to 350sq ft & 3/4 to 1.5oz spin cloth usually flown free with or with-out a sock or a top down spinnaker furler of ur choice & require a torsion line
So back to head sails
Standard 150% Genny 206sq ft
Code Zero 185% very powerful Approx 284sq ft, 165% a little less power 237sq ft if u stay with the original Luff length u can also add another mast hound 12" above the jib mast hound on an
18" above on an
& fly it higher of the deck too catch more air , if u go longer luff on the sail the sail will b bigger . Code Zero will b more expensive $$$$
Generator/Drifter 165% powerful Approx 237sq ft approx 2/3 rds the size of a 350sq ft cruising spinnaker , 150% less powerful same sq ft as ur standard Genny at 206sq ft. this sail can b flown free with or with-out a sock or on a Code Zero bottom up furler . Generator is a lot cheaper the cost $$, Drifters u,d have to price, FYI a flat cut Generator & Drifter r basically the same sail Altho it looks like the Peak sail Generator has more re-enforced Head , Tack & clew ?
On a note I talked to Chris Stevens this morning from Peak Sails in Florida he told me he usually suggests the 150% Generator for the
because of their lightness of the boats & some sailors lack of experience
after I told him about boats cutter rig he said he,ll make me one as big as I want
Also he suggested adding dyneema line to the luff at no extra cost for better sail shape if using a Code Zero bottom up furler
FYI they have the Generator on sale right 9% discount & up to 20% discount on other sails plus free shipping right now ! until May 22nd 2022
so I,m getting a quote on a 1.5Oz Generator 185% LP
Sheppie
Thats a nice deal on that Blueshark Code Zero furler just so as u know 2502/2503 is a code zero bottom up furler & the 2502E/2503 is a top down Genaker/Spinnaker furler for $60. more, only has a 4" furling drum I,d prefer something around 5" drum like the profurl Nex 0.9 but at twice the cost bigger drum means easier furling
. I see the 2504/2505 is almost 5" furling drum from $570.
https://www.ebay.com/itm/325113363504?_ ... 101224.m-1
I,ll let u all know what the price will b for my bigger generator & what size I decide to go with gotta head down to the boat & take some measure ments
PS I had to edit this as I mistakenly classified the drifter in with the Gennaker/Spinnaker class where as it should be classified in with the Generator/Drifter as it is basically the same sail ! I already have a 300sq ft Drifter but it is not fully flat cut has a slightly curved Luff & small belly so can't point as high as a flat cut Generator/Drifter I had it custom made for my
so I was not selling it with the
I kept it for my
along with my
Storm sail which I can use as a Staysil along with my storm sail on my
think running two storm sails close to the deck cutter rigged I know I,m possessed
6 head sails
