Planning on replacing it in the Spring when the boat thaws out. Glad to hear you had good results.Highlander wrote: ↑Wed Nov 15, 2023 3:18 pm Russ ,
get the high performance steering cable from BWY way better quality as it,s designed for high performance engines with high torque pressure on the steering system , I posted my mod on here about how I went about it & the issue,s I had because I have so much wiring running thru the floor hole for the steering cable , replaced & zero play afterwards
J![]()
Sloppy Steering (video)
Re: Sloppy Steering (video)
