NautiMoments wrote:I have also been searching for the right prop for my Honda 50 on a 2005M. The problem I am having is Ventelation, air being drawn down from the surface, when i am in turns with ballast empty or just motoring in small chop with ballast full. The transom design puts the motor so close to the surface and when you have ballast in the bow is down more than the stern. I know most people I have talked to with M's are having the same problem. I am wondering if a smaller diameter is better, possibly the 4 blade like Terry runs. Anyone else solved this problem.
aya16 wrote:The bow down att. of the M is not a bad thing. when running at speed through the ocean I find the boat does not slam at all. Also by placing a 90 on the back doesnt seem to effect the bow down att. as seen on scotts boat with a tohatsu whatever you call it. As mentioned before when the boat is at the dock with no one on board the boat sits bow down but as you add people and gear to the aft it almost evens out.
But if the boat is brought to a bow up att. I can see where slamming will happen at speed. ..
Sounds like a design improvement on the 26M - but a 2-edged sword. The factory was trying to improve on the 26X, and maybe you're just fighting the design compromises.
A criticism of the 26X, regardless of motor weight, is that it never quite manages to climb over its bow wave. This gives it a radically bow-up attitude when planing. (Many might say, "... it's just trying to plane.") It's rumored that they slightly repositioned the 26X ballast tank in '99 because of bow-attitude and because of the trend to heavier outboards.
First words of wisdom from my Mac dealer were: "Use your ballast if you want a stable, but very wet, Bay crossing ... ballast empty for a quicker and a drier ride!"
Seems to me that the M-owners have a big advantage, both for planing and for beating under sail (mitigating wx-helm). But, perhaps Macgregor's attempted correction, if any, has a gotcha ... sounds as if the lighter-weight motors carry the prop too shallow? As Mike observes, that's still not a bad thing. It provides lots of spare, "crew" buoyancy. It also means you never need worry about a full load of fuel, ice, beer ... or all four.
I'm not a pilot, but one can see by reading that load-balancing is no mystery to the pilots in the group. M-owners might recognize your advantages, concentrate on your waterlines, and load your boats accordingly. (& don't forget that if your motor is only 200#, there might be another 200# of reserve buoyancy back there.)
Next 26M mod, starb'rd aft berth sliding track with twin 70qt. coolers!
