Tiller Pilot project for 2002 X
Re: Tiller Pilot project for 2002 X
Ill have to get back to you on this...its a distant memory....I hope I havent led a bunch of people astray..... :| :| :|
Your numbers sure seem to imply its not possible..
bartmac
Post by bartmac »
We've got a Raymarine sportpilot on our 26X ....I installed it between the wheel and steering shaft.It's probably not designed for a sailing vessel but does the job really well.It has a stalk mounted on/off switch and incorperates a sensitivity dial.It has GPS inputs which we haven't done as yet.The beauty of this device is even on you can still steer manually and as soon as you let go of the wheel it continues on that heading.It reacts to gusts rather than anticipating but that's to be expected.And as we only have 15hp on the back the use of this while motoring is quite safe.
However the use of a tiller pilot is something I considered as originally I was going to convert our boat to tiller steering to free up cockpit space and as all sailing I had done was using a tiller......still have to think at times about wheel V's tiller input to gusts and small boat movements
fouz
Post by fouz »
Is this still working good for you? Anything to add after 3 years of use?
I'll be using it this weekend on Cape Cod...maybe I can shoot some video
