Posted: Wed Feb 27, 2008 2:23 pm
hahahahaha...never thought of that!The M in the same configuration would have me staring at myself---not a pleasant thought.
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
BINGO~!!Billy wrote: . . . I don't look at it as upgrading or downgrading, but rather what fits.![]()
What did you expect? Here's why the X, even for a couple:Compromise wrote:There is a definite hint of X vs M here which I was hoping to avoid. Apparently it's unavoidable.
Actually, I have and took some of the pictures here.Divecoz wrote:Moe as you have never been on a M...
You seldom raise the jib, so I can see why. Several M owners here have added them to deal with a sagging forestay.Divecoz wrote:I don't need a back stay never did...
Yes, but they had to be led outside the winches, and as Duane pointed out in an earlier thread, cover the best area for walking forward.Divecoz wrote:I have always had, all my lines leading back. Thru rope clutches btw.
Anyone visiting the Mods pages will see that not the case.Divecoz wrote:Mostly I see X boats on this board are using cheap cam cleats not rope clutches.
More accessible, yes. Larger, no.Divecoz wrote:I have a larger and more accessible rear berth on my M
These days, I don't scamper anywhere, but I never had a problem getting in the aft berth since the ladder folds up.Divecoz wrote:( another test lets see moe scamper in and out of the X's rear berth)
It's the main cabin in many boats, some of which have no aft berth.Divecoz wrote:VERY few sailors sleep in the v berth!
If you're going to restate Terry's post, at least give him credit for it. When underway, when it really counts, do you want to have to move cargo out of the high CG forward v-berth to the aft berth?Divecoz wrote:Basic Geometry says it's the wrong place to be! On the X its the very worst place to be or to sleep!! The boat is at its narrowest and your at the highest center of gravity( with a LOT of weight) in the boat !
Anyone who's used the forward dinette seat on the M knows better.Divecoz wrote:Dagger-board is nowhere near the dinette on my M...
Not snapping, but certainly damaging. Leon was one (original board).Divecoz wrote:but your right it wont swing up during a grounding. Center boards seldom do that either again just another in the list of misleading claims by moe. Has anyone posted snapping a D-board yet on an M ?
The Wallas stove-heater takes the place of an Origo stove. Because it has a "chimney" it can't be installed in a sliding galley unless that is fixed.Divecoz wrote:You can mount a Wallas heater in and M and on just about any boat...why would anyone give up space on a small counter top in any boat to a heater...
So do X's built in '98-'99 and later.Divecoz wrote:On The M BTW the ballast Vent is forward and has a built-in capture well around it
Okay. The tanks are forward of the generator, so switching the hose is no problem. There is back porch aft of the generator, which is easy to step over.Divecoz wrote:Show me an EU 2000 not 200btw that sits permanently and securely and is usable in space under the helm seat and it would not be a problem changing fuel lines at the motor... with that big gennerator in the BackPorchcan you still scamper up and thru...
X owners are laughing at that one. It really calls your credibility into question. There is PLENTY of room for even the largest person to board over the transom on an X, and most X owners have done so.Divecoz wrote:85% of the adults out there still couldn't get in and out with the use of that ladder Its still too narrow.
When unballasted.Divecoz wrote:It proven that the M has the additional edge of stability because of its permanent ballast .
Yes, Mark Prouty's, where the modification actually caused the damage.Divecoz wrote:The Only Transom failure ever noted on this board with over how many 1000's of boats represented ! Yep it was on an X...
R King wrote:"People, I just want to say, you know, can we all get along? Can we get along? Can we stop making it, making it horrible for the older people and the kids?...It’s just not right. It’s not right. It’s not, it’s not going to change anything. We’ll, we’ll get our justice....Please, we can get along here. We all can get along. I mean, we’re all stuck here for a while. Let’s try to work it out. Let’s try to beat it. Let’s try to beat it. Let’s try to work it out."
