Hi All!
We’ll finally finished cementing in the three slab floor receptacle boxes and conduit!
That took way too long!
But it’s done and level to the original slab!
Now I need to move stuff around and get started on the installation of the new vinyl plank flooring.
I’ve been a bit of a lazy bum os sorts the past couple of weeks with the recent hot humid weather and some health stuff.
I could really use a couple of my prior 20-something selfs about now.
All this bending over, crawling around on my knees and carrying heavy stuff was my younger self forte… not my current older/wiser stiffer less flexible version!
All I can say is it’s not gonna get done by itself….. so I’m gonna have to get on with it.
I’m told it goes fast once you get started on it….
Meanwhile I’ve been giving some thought regarding next season’s boat work list.
Aside from the wheel lug/hub removals and stud replacements for 4 wheels it’s gonna be time again for a new coat of ablative bottom paint. I’m glad I made the support frames from last time sturdy and reusable!
It should go a lot faster!
Painting……
Phase 1:
The benefit of delay is that we’re now hoping to start progressively painting at the beginning of next season starting with all the removable hatches as well as the helm seat. These have all experienced some wear and tear since they were manufactured back in 2001. ( I have too
) The helm seat and anchor locker have seen several manageable small cracks show up that I’ll repair /reinforce first before painting. The sliding hatch could probably use some TLC as well on the sliding surfaces as well as reinforcement of those two notches where it slides over those side crownings. I’d be modifying the fwd & aft lips anyway so it can seal up better to the removable panel to better keep in the A/C and heat. The gelcoat is pretty much shot on these covers.
For the helm seat lip that takes all the shock load when it inevitably slams down I’m going to also modify things so the area where the base of the seat contacts the cockpit side bench area is now the first point of contact with a compliant bumper like a nitrile or viton rubber pad. That will somewhat distribute the forces over a larger more robust area. Ideally when all is said and done the helm seat backrest lip will not be in contact anymore so the problem won’t reoccur.
These will give us some manageable practice before we tackle the top deck the following season.
Phase 2:
The following season….
After some minor refurbishment/modifications to the pedestal we hope to work on the top deck above the rub strip (which I’m not planning on removing as we replaced it back in 2021 and it’s in great shape
One of the prep aspects is the removal/replacement/rebedding of the cabin windows.
(We would <3 LOVE <3 to figure out some reasonable way to be able to open/close/screen at least one window per side…. Any ideas? Anyone?)
My only logistical debate is do we paint the raccoon stripe before or after the deck?
We’ll be using paint encapsulated ’soft sand’ to retexture the anti-slip.
I mention this as I’ve tried several small touch ups of the gelcoat and have not had much success in getting it to match the existing aged factory surfaces. The boat repair and body shop guys I’ve managed to have talked to have all pointed me in the direction of new paint rather than new gelcoat. While gelcoat ‘May’ last longer the prep and blending refurbished surfaces to existing surfaces is much more intensive and the overall process much more expensive. Paint is more forgiving, easier to prep, apply, blend and touch up as well as much less expensive by a considerable amount over gelcoat. A three layer two part epoxy paint job will easily last a decade and probable much more at a fraction of the cost of gelcoat.
Drum winch:
Prices on anchor drum winches have climbed exorbitantly since January.
I’d been hoping to get one out of Australia as they have a stellar reliability and durability compared to the others I’ve evaluated.
Hopefully that might change but I’m not gonna hold my breath so that’s moved to the “indefinite hold” status. Bummer!
Hard Dodger and Mast Tabernacle:
Depending upon how things progress with the house remodeling goes here in SC and up in NH I’m hoping to get started on these sometime in late early summer 2027 after the top deck painting and new window installations are completed.
Shore / Generator Power power inlet and electrical panel:
So this is looking like an early 2026 Spring project.
I have most of what I need material wise already.
The exterior inlet location is on the port stern high on the interior wall behind the helm seat.
That should be reasonably accessible for shore power connection as well as to the portable Honda generator we can carry if needed.
The AC interior electrical panel with two circuits and two breakers will fit alongside our DC electrical control panel.
It will have two resettable breakers and two receptacles for each breaker.
I’ll fab things up in what spare time I might have ahead of time so the installation can go smoother than figuring it out as I go….
New Aft Enclosure:
That is another item that has risen in cost over our budget these past several months.
Seriously considering taking a different approach with making a screen enclosure by glueing/stitching Velcro strips to our existing Bimini arrangement. Not perfect. Probably not pretty. Probably with limitations and some level of fuss factor but it should at least discourage the bugs to some degree. Gonna forego the vinyl curtains so that means I’ll most likely get wet when it rains and cold in the cooler seasons. But there’s no way the budget is gonna absorb the costs involved with a bought enclosure system based on the current projected economic forecasts. It is what it is it appears for at least several more years to come. Just one of those things one has to deal with.
The Velcro DIY is estimated to cost about less than $300 in materials vs several thousands for the bought unit.
We’ve done ok so far without and the screening would be our biggest benefit when traveling the ICW routes.
The salt marsh mosquitoes and horse flies can be most annoying at certain sections along the ICW from what we’ve been able to find out about in our researching.
(Worse comes to worse it’s always possible to cover up with long sleeves, slacks, bug headsets and bug spray.)
So this has fallen way down on the project lists.
ICW Trips:
While an extended trip didn’t workout for us this year we hope to take one next year for 2 to 4 weeks duration headed north on the ICW from Beaufort, SC. The current thought is to travel out on the water and return via trailering. That way we can get more of the ICW traveled without back tracking on our selves. The advantage of a trailerable motor cruiser sailboat!
That the planning for now anyway. But as we all know everything in life can change in a heartbeat.
Best to enjoy the moments when they are happening.
Hope everyone has a fun, happy, safe Labor Day Holiday with family, friends or doing something you enjoy!
Best Regards
Over Easy
