OK.. hardware list:
I still have the original jib & genny tracks & cars and all original standing rigging, though I replaced a couple of spreaders, bent one running it into a tree near the launch ramp and bent one about a year later while rigging. Also some forestay changes, see list below.
I. lifelines and pelican hooks. Couldn't stand the stock pelican hooks, they would constantly open (dangerous.) Original lifelines frayed at the stanchion hole inserts after about 2 years. I now have have 3/8" rope lifelines outside the cockpit. I like these more than wire (much better to hold on to.) The cockpit lifelines are 1/4" steel cable coated in white rubber, also much nicer to hang on to. Pelican hooks don't open bythemselves.. a nice touch
2. Mainsheet blocks, new Harken hexarachet 6:1 purchase. Great for playing the mainsheet in gusty winds with minimal effort due to the hexarachet 10:1 additional holding purchase.
3. All lines aft using Ronstan & Harken blocks plus Spinlock clutches. I guess nothing replaced here, just added.
4. Vang attachment point on the mast (flimsy padeye) broke. Bolts snapped. I now have a bail on the mast which is a much stronger connection. I believe the
boats use this connection. Not sure why they changed to the whimpy padeye on the
5. Installed cam cleats for the rudder lines.
6. Replaced latch for sliding galley. Original broke so I installed one a bit more heavy duty.
7. Replaced 2 forestays. Original slightly frayed but usable, but at the time, I wanted a 5/32" cable. Served for 2+ years. Recently noticed heavy fray at the top, just below the swage and above the top of the furler. At least half the strands broke.
Glad I caught that one in time. Replaced with factory 1/8" forestay.
8. Replaced factory daggerboard after two heavily dammaged stock boards involving no groundings. No have a 180 lb ballasted board (custom made.)
9. Replaced block for DB line. Original wasn't desgined for heavy loads like this and it finally stopped spinning. Also installed 6:1 block & tackle for the board.
10. Replaced factory engine linkage with BWY quick disconnect linkage and fixing stud.
11. Galley faucet broke. I also replaced two water bags that leaked, so I took the opportunity to install running water; pump & faucet & 13 gal plastimo water bag.
12. Had two porta potties leak
Installed a Dometic head with pumpout and pressurized flush. (very happy with this unit.)
OK, that's all I can think of for now. I guess not too bad a list, but I haven't touched on the electronics, sails, canvas, etc.
Got one more trick up my sleeve. Should be a really cool mod, but I can't talk about yet. Stay tuned.
fair winds,
LD
TRIPPLE REEFED
