Page 4 of 4
Re: porta potti
Posted: Thu Oct 29, 2009 10:58 am
by Kelly Hanson East
You would have to manually load it with water if it wasnt plumbed in..I dont think it needs a pressurised water system, just a supply. I believe the flush action is pedal controlled.
Link to the product on the WM site...you could probably get a manual off the web from the MFG.
http://www.westmarine.com/1/1/21173-711 ... aland.html
On edit - this info is wrong - see below. Unit requires pressurised water.
Re: porta potti
Posted: Thu Oct 29, 2009 12:21 pm
by Hamin' X
Looking over the spec sheet,
located here, I do not find anything resembling a pump in the unit, only a simple valve that is actuated with the pedal. Seems it must have pressurized water plumbed to it.
Cheapest price I found Here.
Re: porta potti
Posted: Thu Oct 29, 2009 12:48 pm
by bubba
This reminds me I need to clean ours out now, from sailing on Pudget Sound last weekend. I think a 5 gal tank is heavy enough to carry in our Mac's.
Re: porta potti
Posted: Thu Oct 29, 2009 7:20 pm
by Gypsy
Do you have it plumbed to a deck fitting or are you pumping it out thru the toilet ?
Re: porta potti
Posted: Thu Oct 29, 2009 7:48 pm
by K9Kampers
Kelly Hanson East wrote:You would have to manually load it with water if it wasnt plumbed in..I dont think it needs a pressurised water system, just a supply. I believe the flush action is pedal controlled.
According to the mfg's manual, incoming water is pressurized at 5 - 80 PSI. Water in & flush out is contolled by the pedal - like an on / off switch, not pump action.
