Tip of the day ...Post yours
JohnCFI
Re: Tip of the day ...Post yours
Post by JohnCFI »
Whales like a little distance from your boat
Whale breath stinks!!
(Both tips found out by accident)
Tip 3, Look where you are going!!
Baerkanu wrote:BWY's suggestion was to keep a dock line tied to the bow cleat and run back to the stanchion just forward of the cockpit, tied off with a clove hitch - it's far enough back that you can control both bow and stern when launching, docking etc. That's been a priceless tip as well!
- Clay
Ray gave that tip to me as well. Good idea to have a "handle" to grab the boat from on the dock.
Use a piece of wire (preferably stainless) to lock the anchor shackle so it can't unscrew. Same with rigging shackles like the headstay.
Toss a dryer fabric softener sheet in your bedding to keep it smelling nice and repel insects. Also toss them in bilge areas for same reason.
RobertB
Post by RobertB »
Make sure you have fresh limes to go with the Tequila
bartmac
Post by bartmac »
GO SAILING MORE OFTEN!!!!!!
Never use the "aft head" while running.
Ormonddude
Post by Ormonddude »
A Medium sized cooler makes a nice elevated captains seat when maneuvering in tight or congested areas and you need a real good view.
Johnacuda
Post by Johnacuda »
Don't tug on superman's cape.
kmclemore wrote:
cptron wrote:Don't spit into the wind, It will throw it back at you.
...and don't pull the mask off that old Lone Ranger and don't mess around with Jim.
doo da doo doo do.
Johnacuda
Post by Johnacuda »
Oh yeah, when your boat is on the trailer, always make sure to raise the transom swim ladder before you back up. Mine is slightly "contoured" now.
Gater Dunn
Location: Victoria B.C. Canada N48º25.506 W123º18.178 OakBay Marina
Post by Gater Dunn »
there are no stupid questions only stupid mistakes
sunshinecoasting
Post by sunshinecoasting »
Make sure your mast raising pole on your :macx: is not tied to your mast when lowering the mast. It will bend the step plate completely out of shape and you will wonder why the mast does'nt weigh much until it lets go with a bang and drops about 4 feet......ask me how I know
.......now where is my hammer and dolly to flatten out that plate?
Dennis.
sunshinecoasting wrote:.......now where is my hammer and dolly to flatten out that plate?
Dennis.
Always nice to have a lovely female assistant. ;)
Post by K9Kampers »
If my boat is a-rockin', don't come a-knockin'!!
...don't mess around with Captain Jim....
Find a good Ale that you like to keep aboard. Ales are best served at 68 degrees, and therefore don't require a coldbox or fridge. Also the bitterness slows you way down and keeps you from over-indulging. India Pale Ales are so named because they were brewed specifically to be kept at room temperature of the holds beneath the waterline on British merchant ships transiting to India.
Also get the Admiral to find a red wine she likes for the same reason. A slight change in food and drink preferences can eliminate most of your power draw.
Phil M
Post by Phil M »
mastreb wrote:Find a good Ale that you like to keep aboard. Ales are best served at 68 degrees, and therefore don't require a coldbox or fridge. Also the bitterness slows you way down and keeps you from over-indulging. India Pale Ales are so named because they were brewed specifically to be kept at room temperature of the holds beneath the waterline on British merchant ships transiting to India.
In Canada, our waters are generally a bit cooler, and beer that is stowed in the bilge area is almost cool to drink without any refrigeration. But the beer is both stronger AND better tasting, so be careful. 8)
