Page 4 of 5
Re: Tip of the day ...Post yours
Posted: Mon Jun 03, 2013 10:39 am
by JohnCFI
Whales like a little distance from your boat
Whale breath stinks!!
(Both tips found out by accident)
Tip 3, Look where you are going!!
Posted: Mon Jun 03, 2013 11:16 am
Baerkanu wrote:BWY's suggestion was to keep a dock line tied to the bow cleat and run back to the stanchion just forward of the cockpit, tied off with a clove hitch - it's far enough back that you can control both bow and stern when launching, docking etc. That's been a priceless tip as well!
- Clay
Ray gave that tip to me as well. Good idea to have a "handle" to grab the boat from on the dock.
Use a piece of wire (preferably stainless) to lock the anchor shackle so it can't unscrew. Same with rigging shackles like the headstay.
Toss a dryer fabric softener sheet in your bedding to keep it smelling nice and repel insects. Also toss them in bilge areas for same reason.
Posted: Mon Jun 03, 2013 12:40 pm
by RobertB
Make sure you have fresh limes to go with the Tequila
Posted: Mon Jun 03, 2013 2:59 pm
by bartmac
GO SAILING MORE OFTEN!!!!!!
Posted: Mon Jun 03, 2013 5:38 pm
by mastreb
Never use the "aft head" while running.
Posted: Mon Jun 03, 2013 6:32 pm
by Ormonddude
A Medium sized cooler makes a nice elevated captains seat when maneuvering in tight or congested areas and you need a real good view.
Posted: Mon Jun 03, 2013 7:55 pm
by Johnacuda
Don't tug on superman's cape.
kmclemore wrote:cptron wrote:Don't spit into the wind, It will throw it back at you.
...and don't pull the mask off that old Lone Ranger and don't mess around with Jim.
doo da doo doo do.
Posted: Mon Jun 03, 2013 8:29 pm
by Johnacuda
Oh yeah, when your boat is on the trailer, always make sure to raise the transom swim ladder before you back up. Mine is slightly "contoured" now.
Posted: Mon Jun 03, 2013 10:27 pm
by Gater Dunn
there are no stupid questions only stupid mistakes
Posted: Mon Jun 03, 2013 11:53 pm
by sunshinecoasting
Make sure your mast raising pole on your
is not tied to your mast when lowering the mast. It will bend the step plate completely out of shape and you will wonder why the mast does'nt weigh much until it lets go with a bang and drops about 4 feet......ask me how I know
.......now where is my hammer and dolly to flatten out that plate?
Dennis.
Posted: Tue Jun 04, 2013 8:09 am
by kmclemore
sunshinecoasting wrote:.......now where is my hammer and dolly to flatten out that plate?
Dennis.
Always nice to have a lovely female assistant.
Posted: Tue Jun 04, 2013 8:50 am
by K9Kampers
If my boat is a-rockin', don't come a-knockin'!!
Posted: Wed Jun 05, 2013 4:30 am
...don't mess around with Captain Jim....
Posted: Wed Jun 05, 2013 11:15 am
by mastreb
Find a good Ale that you like to keep aboard. Ales are best served at 68 degrees, and therefore don't require a coldbox or fridge. Also the bitterness slows you way down and keeps you from over-indulging. India Pale Ales are so named because they were brewed specifically to be kept at room temperature of the holds beneath the waterline on British merchant ships transiting to India.
Also get the Admiral to find a red wine she likes for the same reason. A slight change in food and drink preferences can eliminate most of your power draw.
Posted: Wed Jun 05, 2013 4:16 pm
by Phil M
mastreb wrote:Find a good Ale that you like to keep aboard. Ales are best served at 68 degrees, and therefore don't require a coldbox or fridge. Also the bitterness slows you way down and keeps you from over-indulging. India Pale Ales are so named because they were brewed specifically to be kept at room temperature of the holds beneath the waterline on British merchant ships transiting to India.
In Canada, our waters are generally a bit cooler, and beer that is stowed in the bilge area is almost cool to drink without any refrigeration. But the beer is both stronger AND better tasting, so be careful.
