Suzuki DF70A or DF90A uprade from Honda BF50 carb?
Starscream
Re: Suzuki DF70A or DF90A uprade from Honda BF50 carb?
Post by Starscream »
milest wrote:Hi everybody,
I ordered DF90A with 3X14X13 prop for my heavy :macm: with bottom paint.For a spare I found this one http://boatpropellers.iboats.com/Suzuki ... =117732590
or I should go for that one http://boatpropellers.iboats.com/Suzuki ... =117732590 ???
There is no way to predict which is the right one. You need to get your boat on the water with a trial prop and then use the results to figure out where to go from there. Your first link is a 14x11x4, which is the right choice for my E-tec 90 on my heavy X with bottom paint; however there are other X's out there with the same motor that would have no trouble swinging the 15-pitch prop shown on your second link.
I would take your 3x14x13 prop for a test run, both ballasted and unballasted, and post the results here for good advice on your next step. I personally wouldn't buy a second prop until I had data in hand.
milest
Post by milest »
What I have read on this forum makes me feel that I should go for the same prop as you mentioned as 4X14X11. It's also good to have the data from the stock 3X14X13 prop. (same conditions like Stefan has in black sea :!: )
Thanks a lot..
milest
Post by milest »
delivery problems.....need to wait 15 days more.....
they don't have any 13 pitch prop
.... :x :x :x
milest
Post by milest »
Hi guys,
at last my beast was installed on 16th. of May
here are some photos:
http://i1148.photobucket.com/albums/o57 ... wf9yt7.jpg
http://i1148.photobucket.com/albums/o57 ... xbbjvs.jpg
http://i1148.photobucket.com/albums/o57 ... jx9khz.jpg
I don't have any data for performance...still break-in period.
vkmaynard
Post by vkmaynard »
Exciting.
Keep us posted
Victor
milest
Post by milest »
just tested.....
fully loaded without ballast ,4 people,80 watts solar,45 kg. lead in the keel,45 kg. batteries,12v 50 lt. fridge full,30 litres of fuel,bottom paint,mast up and sails on:
Solas 13.75X13X3 prop with rubex 150 kit installed and I easily hit 6200 rpm... no gps data.. but I was suprised;she planed so quick.May be I can use the stock prop 13 7/8X15X3..???
vkmaynard
Post by vkmaynard »
If you can rev past 6200 then you need more pitch.
Victor
tek
Post by tek »
milest wrote:I have news guys;
Prices updated by the dealer.... 70A-90A difference droped to $400 8)
if I pay $800 more I can buy the 115A (2044 cc.) 8) 8)
But 2044 cc. is huge :!: So I better go for 1502 cc.
Have you looked at the weight difference between the 90 and 115?
milest
Post by milest »
and........
75 kg. of fresh water tank under the aft bed.........!!!!
What an upgrde from 808 cc. Honda BF50A ...It's great!!!
darrenj
Location: Vancouver BC, Canada 1998 26X w/ 2012 Suzuki DF90A
Post by darrenj »
I have the DF90A and with my X loaded for bear can only get about 5300 RPM using the 14x13x3 stock suzuki prop. To get 6200 RPM I need to empty the boat, no ballast and leave the mast in the yard.
I am looking forward to hearing what kind of speed you are getting with the Solas 13.75X13X3 prop
vkmaynard
Post by vkmaynard »
With boat loaded, ballast in, full fuel, 20 gal water, two batteries and two people we were running about 25 MPH.
Need to prop the boat to run 6200 fairly loaded for cruising with no ballast if you want performance with ballast.
Victor
milest
Post by milest »
Thanks Victor,
I tested with ballast and 2 people,same conditions:
hit 6200 rpm again...I noticed they send me 13.5X15X3 prop not the 13.875X15X3 as a stock prop.I can replace with the 13.875 one.
Can't decide which one to choose...????
Any advise...??
Thanks a lot,
milest
Post by milest »
Hi,
I have some data with Solas Rubex 13.75X13X3 prop:
(iphone gps prog)
2000 rpm; 6.5 mph
6200 rpm; 20 mph
with ballast, 2 persons and same conditions....
