Swing Keel rope replacement
Starscream
Re: Swing Keel rope replacement
Post by Starscream »
Flash forward 4 years after dropping the board and replacing the centerboard line.
I replaced it again today. For the last 4 years we had the "upgraded" dyneema line from BWyachts, and unfortunately it wasn't a good choice for the centerboard line. On my boat the line runs through cam cleats, and the cams just couldn't get a grip on the dyneema when it was wet. This led to the board dropping a few times under power, once putting us right over on our side.
I ended up tying a bowline in the end of it and looping it over a dock cleat installed on the genoa tracks, but even this would allow the line to drop about an inch, which means a fair amount of board was still down.
The new line is back to normal braided yacht line, and the cams seem to grip that just fine.
Inspection of the old line: as per my original discovery the main chafe happens at the turn down from the deck into the mast compression post. If you're concerned about your line, check that point first. Where the line goes through the centerboard itself was in better condition on both the original 18-year old line, and the replacement 4-year old dyneema line.
Red arrow shows the chafe point at the turn into the compression post (with centerboard up)
Replacement wasn't too hard. I used my car floor-jack to support and lift the front of the board back into place. Did the whole job myself in just over an hour while the boat was on the trailer, so not too bad.
Hi StarScream!
Thanks for the post about how your Dynema line has held up!
We changed out our standard braided line that we put in place 2 years ago this past Spring and put in Dynema.
This was a ‘while we were at it’ sort of thing as we had dropped the swing keel to apply new ablative this year.
The Dynema has zip for line stretch and seems to be much more pliable while also being much stronger.
At the same time we added a pulley lift to make it easier the lift the swing keel.
The Admiral likes that the effort to raise the keel is half of what it used to be!😊
We used the prior lift line for the pulley line and serendipitously avoided the Dynema/cleat-grip slippage issue.
Really like how solid the swing keel stays in place as well as the reduced effort to lift it.
Best Regards,
Over Easy 8) 8)
