Yep, there's a rope going to a wire outside. It's so tight you can pluck a tune with it, but the board itself is sticking down a little bit still.
Is that normal? It's not supposed to retract right inside its slot?
I kept saying the perspex hatch covers were too weak; today managed to put my knee right through one! Happily it was underneath the front bunk cushion, so no injury. On the bright side, I found some engine spares in there!
I have a new impeller, some spark plugs, a few other bits, also a used rudder controller. I guess he broke one, got a new pair and kept this one as a spare?
I already bought a service-kit for the BF50A, including an impeller, but it's nice to have some extra spares
Have also found the original 3 blade prop. Not sure how to change it - there's a castle nut with a clip. So I remove the clip, find a socket the same size as the nut... but how to stop it turning the whole shaft etc? I've never changed a prop before
I'll try looking on Youtube...
The admiral had her first visit inside today. We were both soon drenched in sweat, but she seems to like it (the Mac, not the sweating bit).
I haven't opened the front hatch yet. Had a quick go today; it didn't seem to open when I thought it would. I suspect PO has actually sealed the thing shut? Will have another go later, as it was getting dark and I don't want mosquitoes in there anyway.
Question - The stainless steel tubing for the life-lines has brackets which have rusted away completely. Any idea where I could find some stainless steel replacements? I'm not even sure what you would call those things?
Today more fun and giggles with the trailer.... I mentioned I had the tongue extended, by having a 20ft section of steel turned into 2 new tongues, one for immediate use, one to be sent for galvanizing? Well the galvanized one was ready the other day, managed to collect it with my truck, this morning tried fitting it...
Scary to have the boat and trailer dangling on a 3 axle stands...
But got it on... and the holes don't line up
The same company did both tongues, at the same time, from the same piece of metal, using the same original as a template, so how can it be that this one doesn't fit?
Then I noticed the state of the other, non-galvanized one I just took off...
Judging from that butchered hole they knew, full well, that it could not possibly line up - but they sent it off to be galvanized anyway, at my expense, plus the cost of the truck to and from the galvanizing place? Knowing i'd have to re-drill it, ruining the whole point of galvanization?
There's a lot of love about Malaysia but people like this, with this kind of mind-set, is why it remains a 3rd world country. In Japan they organized getting the boat out of the water, into a container and shipped it here. The local people took 2 or 3 hours getting it out of the container and the local "engineering company" can't drill a hole straight? Not to mention the trailer being too small in the first place... and don't get me started on ROC numbers...
Yeah, it's going to be quite a project, and HUGE frustrations, road-blocks, delays, hassles and annoyances buying and getting it here, and onto a trailer. Not an experience I'd like to repeat - but as I just said to my Admiral, it's finally here, in my garden. It's my Macgregor, which makes it the best Macgregor in the world.
The world!
