Yes Here u r I believe this price was for a longer luff length of 27' 5" so as to fit above my Jib hound as my additional Genny hound is mounted approx 30" higher than my jib hound
A custom 165% Generator with additional luff length provides a sail of 215 square feet.
The price would be $604.32. Please note this price does not include any discounts we are currently offering.
price for a reg 165% generator is USA$578.08
as of if u want to add a top down furler u will need to buy a mast hound from BWY or ur local marine store that sell sail boat hardware mount it approx 18" above ur Jib mast hound attach a good ball bearing non swivel halyard block then a new Spinnaker halyard to the dedicated spinnaker mast hound & a good quality snap shackle to the spinnaker halyard, tie a boat hook to ur bow roller run the spinnaker halyard out to the boat hook make sure u cleat off the other end of the spin halyard first then determine how far out u want to go I,d say 18"-24" would b fine , then attach a measuring tape to ur spin halyard pull it to the top & that length will b ur Max luff minus top swivel & furling drum length u will want ur furler hoist length to b at least 12" shorter to allow for stretch so as u can tighten the furling luff torsion line if u go with a top down furler
a short bowsprit like BWY has would b fine if too long it,s a pita to install or remove on the water my Genny furler is out 3ft & my Spinnaker furler is 4ft out on the end of my 4ft bowsprit I,m going to make an folding attachment bar that will fit on top of my bowsprit that I can unpin & lift to a vertical position for installing & removing , u can just buy an Alum tube thick wall from any metal super market it comes in two grades low grade & high grade high grade is a lot stronger that,s what u want & make ur own & attach it to a 1/4" thick U channel with backing plates under the deck or other means dicussed earlier
https://thesailwarehouse.com/cgi-bin/we ... l&cart_id=
go to measuring sails top left on this link & look at the head sail section
