Posted: Tue Dec 06, 2005 10:56 am
I posted earlier that December Sailing magazine (also Sail magazine, Practical Sailor and others) printed a long article on COB recovery. Upon skimming same article again, I note that they have a link for their event at www.COBevent.com. It's worthy reading, but the website shows only a few pictures ... the magazine is definitely more useful for conveying the message. (December's Sailing mag should be at your local West Marine store).
IMO, trying to lift a COB over the side of a Mac borders on braindead ... but hopefully not to the COB.
It seems from the quote above that triangular nets, scoops (maybe even sails) used to roll-n-lift an unconscious victim up the freeboard are challenging to use, difficult or painful for the victim and perhaps dangerous in other ways too. Without any doubt after viewing pictures, this could work acceptably only if the outboard corner is hoisted to an outboard block - a block suspended at end of the boom for example.COB-Event (SF Bay2005) wrote:Retrieving an unconscious victim from the water was a daunting task. The following strategies were tried and the results were not entirely satisfactory:
- * Bosun chairs and safety harnesses were attached to the victim by a helper in the water. This was viewed as a marginal procedure because of the considerable difficulty and time it took to carry out this procedure.
* Dropping an already inflated dinghy in the water was a reasonable approach to the unconscious victim scenario but not without its difficulties.
* The Jacobs Ladder was used (It is a specialized device that is three and a half feet wide and several feet long. it is designed to attach to the toe rail and dropped in the water in order to maneuver the body into it. A halyard then lifts the device and body up.( This worked well in the company's video when a rubber dinghy was used but on a sailboat with a much higher freeboard, it did not work well..
* Putting a sail in the water, much like the Jacobs Ladder (one side was affixed to the deck and the other end dropped in the water to allow for the potential of maneuvering a victim in the bight of the sail.) This could only be described as terrible since the victim rolled face down where the potential for drowning was all too clear.
Just a personal opinion, but as I've written before, I thnk my adjustable backstay provides the perfectly located solution. It's always rigged & available, provides a multiple of 6 or 8 purchase and hoists the shortest possible distance (to the aft deck). Besides all that, it's adjacent to the only hydraulic hoist on the boat - the outboard motor lift - should one need that extra help.Sailing Magazine wrote:By far the most effective method of hoisting someone on board still proved to be the Lifesling ...
The testing discovered that bringing the person aboard worked best when a strong block & tackle could be attached at least 10 feet above deck, or an extra halyard could be led to a winch. What delayed retrievals most during the testing was the time it took to rig up a hoisting method ...
In the end, any skipper who goes to the trouble of carrying a Lifesling on the stern should know how to use it ...
