Ah ha! On several points things are clearer... and now I see- previously in my mind I had the brackets spreading facing rearward, instead of downward.
I couldn't launch today, so between passing storms and downpours I bodged the following patterns...
There's not a lot of room to put much reinforcement there, and still allow full range of movement (both steering, and deploy/retracting), but the patterns here are out to the max size allowed, so real-world parts will have to be no larger. Off the top of my head I'm picturing 1/4” thick stainless (say, 304L for weldability) here, but 3/16” might suffice.
The very simplest, but least rigid, is a single piece that would just be welded on the outside of the present factory bracket to help reduce the spreading lower down. The width (less than 3/4” ) can be maximized if they are placed so they are level with the space between the 4 mounting bolts at the transom. For more strength you could also use two, one above the other. Welding a thicker piece of metal onto a thinner (factory bracket) piece is less than ideal, but workable, and placing the weld on the bottom allows a possibly unsightly weld to be invisible. Placing the piece just back from the edge by a 1/2” or so, and not right at the edge, will make a better weld too.
In another scenario the larger piece shown would mount below the existing bracket with a reinforcing piece, similar to the one above, welded on the outside. There's room there, and your wings would attach adjustably to these, Crikey. The pivot bolt would need to be replaced with a longer one (maybe bigger too, you could drill out the rudder for 7/16” or 1/2” bolts). I didn't deal with the stop tab, it could be removed and replaced, or a relief could be cut out for it. This makes use of the factory bracket too.
These are geared toward holding the factory tabs in, they don't provide any direct support by bearing against the rudder itself. But placing poly or similar pads of the right thickness inside them would help support the rudders directly.
I'm not really set up to efficiently undertake a project like this, but these are my thoughts, probably similar to what others had, but feel free to use whatever you can from it, if anything.
Has anyone looked to see if Tattoo made any changes in this area?
- B.
