Loala, The Blueberry is a Walmart Lifetime 'Lotus' 8' sit on top kayak which we bought online and had delivered to a local Walmart. It holds my weight.Loala wrote:Hey Doug, what model kayaks are you towing? They look like they don't fill with water and cause resistance or sink!
Last year, we added Melon (teal one) which is a Sam's Club Lifetime 'Hydro' 8.5' sit on top kayak. It's bigger than the blueberry but holds less weight by 25lbs.
Both are Lifetime brand kayaks.
They tow really well and don't sink. Over the course of a two week vacation, they may take on a 1/2 to 1 gallon of water but are easily drained.
The do act as sea anchors. I seem to loose about 1 to 1.5 mph speed under sail depending on conditions. The bigger loss is under power. Without them, even with Galactica fully provisioned (which she typically is) I normally can cruise W.O.T around 19 mph with full ballast. It's closer to 15.5 W.O.T towing the kayaks.
They are easy enough to tow or lift onto the foredeck. You get good at even shortening the lines so that you can maneuver marinas, slips and fuel docks with them in tow.
Doug
