Raymarine EV-100 Wheel Pilot -Mac26X
Starscream
Re: Raymarine EV-100 Wheel Pilot -Mac26X
Post by Starscream »
Raymarine warranty update:
2 weeks ago I submitted my claim online, and sent another email to the warranty department to ask that they send the replacement out before I send them the defective part back (as their standard warranty procedure requires), since the defective part was functional and I didn't want to be without the AutoPilot while waiting to find out if I would even GET a replacement part.
No answer other than the auto-generated confirmation email...EXCEPT...today I open the mailbox and a brand new cable with a nice, soft rubber boot is waiting for me in Raymarine packaging. No RMA, no questions, just a new cable.
So Kudos to Raymarine for the response, although it does kinda suggest that they know the cable boot is an issue, but still. They turned a negative customer experience into a semi-positive one, something that a lot of companies don't understand how to do.
Starscream
We tried the autopilot under some interesting conditions this weekend.
With about a 10 knot wind, blowing 180 degrees over a 1/2 knot current creating some steep 2-ft waves with a wavelength just over half of the boat, we were in two waves at a time, creating some unusual motion.
Downwind (10 degrees off of directly downwind) with just the jib we were sailing at 3mph when falling off the waves and 5mph when surfing down the waves. I could watch the big ones catching up to us, lifting our butt, and spiking the speed. Wilson did a perfect job with rudders down and about 1/2 centerboard.
Coming home, we had to motor into the wind. I engaged the autopilot at 7.3mph, with all fins up, but he just lost it. He couldn't adjust for the wind or waves catching the nose and pushing it off to one side. Without the fins there just isn't enough authority for a small change in wheel position to have any effect at all. So he ended up steering a crazy S, totally out of control. I let him go for a long time to see if he could compensate over time, but nope. Found out that he has three speed "modes": whir, Whir, and WHIRR. Dropped the rudders and his steering was back to perfect.
Overall this is an awesome addition.
ris
Post by ris »
My friend you are correct about the autopilot. Without the rudders down the Mac will not track with the auto pilot.
It will start an S Pattern in the water and then lose track and go in a circle. This is why if you are using a Mac as a trawler you must put a Skeg on the rear to make it track straight with an auto pilot. Without the rudders there is no way it will track straight. We put a 42“ x 6“ tall skeg on the last 42 inches of the boat bottom and she tracks just fine with no rudders. We hope Canada opens up next year as we want to come up and do the North channel Georgian bay, the Rideau Canal to Ottawa then on to Montreal up to St. Lawrence to Sorel Canada and then down to Lake Champlain. We will for sure call you if we were able to do this during the summer of 2022.
Richard
Starscream
Just got back from what is likely our last trip of the year, once again through the Lachine Canal to spend the long weekend in the Port of Old Montreal and be tourists in our own city.
I got to spend some quality time with the Autopilot while the family was cozy down below:
Did some experimenting. With the current settings, the Autopilot can hold +/- 2 degrees in calm conditions, and +/-4 degrees in 1.5mph swirly current with gusty winds. In calm conditions I can manage +/- 1 degree while driving manually, but it takes super concentration.
In combination with the navionics app, these low visibility conditions were a piece of cake. I will say that having the control head mounted on the bulkhead has its pros and cons. Pro: you can tuck in there and be relatively dry in the driving rain. Con: steering on Autopilot requires a lot of button pushing if the channel wanders a lot, and it would be much nicer to do that from the helm or from the cellphone (the Axiom 7 MFD is wi-fi enabled). Looking forward to the next step to add the MFD and sonar.
The chart-plotting function on Navionics is soooo easy. Give your starting and ending location, choose automatic routing, and it will lay out a perfect course through the channel markers. Would be nice to connect that to the MFD and have the Autopilot just follow the route.
In downtown Montreal all the slips were taken at the marina so we parked in the last lock on a public dock for $20/night. No water, power, or bathrooms, but Bear Hunt is self-sufficient for a few days. Son #2 had his 13th birthday on the boat, something which has become a bit of a tradition on labor day weekend. He loves it.
The Canal has low bridges, with the minimum marked clearance being 2.44m. Well, even with the mast removed from the crutch and laid on the bimini, we still contacted the furler hound on the underside of the lowest bridge. No harm, no foul, but an extra 1/2" of water depth woulda been much worse. Coming back, we didn't touch.
Dguy
Post by Dguy »
The EV100 autopilot was one of my 26x’s best upgrades. Using the autobuddy (i3dgear) remote controller I can control the autopilot from anywhere on the boat or cabin (when it rains). Works flawlessly.
panda
Post by panda »
Dguy wrote: Tue Sep 07, 2021 4:03 pm The EV100 autopilot was one of my 26x’s best upgrades. Using the autobuddy (i3dgear) remote controller I can control the autopilot from anywhere on the boat or cabin (when it rains). Works flawlessly.
How does autobuddy connects to the ap?
:macm: 26M 2008, New York
Dguy
Post by Dguy »
Sorry for the late reply. The remote control, I have one on a wristband and another one inside the cabin, sends a signal to a receiver which I have installed in the binacle. The install is simple…I did it in 1 hour and I am not handy at all.
Lokibuster
Post by Lokibuster »
Just wanted to jump on this old (but incredibly useful!) thread, and mostly say thank you to Starscream, ris, Dguy, and others who contributed here.
I bought a 'new' 2002 26X last month and am upgrading it with The EV-100 Wheel Pilot and Axiom+ 7 with Realvision right now. This thread was an absolute shortcut to most of my installation worries (even that sweet tip about the M14x100 bolt). Thank you all!
Two full days of work and the installation is now 'complete'. I still have questions, but am hoping they shake themselves out when I can get it back into the water this week.
Starscream
I don't know who needs to know this right now, but the EV-100 autopilot pack is currently on sale at Defender.com at $1200 US, which is the best price I've seen for a long, long time.
https://defender.com/en_us/raymarine-ev ... pilot-pack
Dang that's a tempting price.
Starscream
Expanding the Raymarine network: added the AIS700 transmitter/receiver. I'm running out of real-estate to mount things :D
The control unit is mounted over the aft port berth, below and aft of the original fuse panel. I mounted the GPS antenna INSIDE the cabin, behind the roof liner of the aft port berth. Not sure if that's great, but the Mac doesn't have the thickest fiberglass to receive and transmit through. Hoping that the antenna is better than the onboard antenna on the Axiom7, which sometimes takes its sweet time to connect. I believe I can select the master GPS signal to use for the system amongst all the GPS-enabled elements on the network.
I added the ghost-mode switch: no need to let all the commercial traffic know that I'm anchored for lunch in a bay somewhere. I haven't been able to test it yet, as the new Seatalk Backbone cable and Tee that I ordered are still in transit, and I haven't made the power connections. That's going to require removing the fuse panel and working around the Axiom 7 in that compartment, which doesn't leave a lot of room to do anything. I really hope I won't have to remove the Axiom to complete the install.
In Canada, I'm allowed to program my own AIS using the ProAIS2 software to add my MMSI. In the USA it's required to be done by a dealer. It was an easy download, and an easy connection from the AIS to the laptop. 10 minutes total, with many re-checks of the MMSI number and dimensional values to make sure, because you only get one shot.
The network wiring is getting complicated.
C Buchs
Post by C Buchs »
Starscream wrote: Thu Feb 15, 2024 8:01 am I don't know who needs to know this right now, but the EV-100 autopilot pack is currently on sale at Defender.com at $1200 US, which is the best price I've seen for a long, long time.
The price went back up for a few weeks, but now it's down to $1150!
Jeff
Starscream
I finished the AIS700 install last night. I hate running wiring on the 26X.
At first the AIS wouldn't show up on the network. It didn't show up until I powered up the EV-100 autopilot and its EV-1 sensor core. Once that was powered up, the AIS showed up and the "targets" option became available. It seems like the AIS700 requires the EV-1 to be operational; my guess is for heading/orientation calculations. It kind of surprises me though; it means that someone who has an Axiom chartplotter can't just add the AIS without also adding a $700 sensor core.
The AIS GPS source did not show up on the network at all. Only the GPS on the Axiom chartplotter was available. If everything is working as it's supposed to, that means the SeaTalkNG network doesn't get access to the AIS700 antenna.
I'm getting a VSWR alarm, which I think is normal because the mast is down and the masthead antenna is disconnected. Fingers crossed.
I hard-wired the AIS700 ghost-mode wires to a switch I mounted next to it, but it turns out that the ghost-mode is an option on the network and that step was unnecessary.
Be Free
Post by Be Free »
Congratulations on your new install.
I'm not aware of any requirement that you have an autopilot installed in order for your AIS to show up on the network. I have seen instances where a device that is powered on after my MFD either don't show up or take a while to show up. Try playing around with the startup sequence.
You are not going to see the antenna on the network as an individual device. It's just a piece of the AIS. Some GPS antennas are stand-alone devices that put data directly on the network but that is not the case here.
I'm surprised to see that the position data is not available on the AIS700 NMEA0183 connection at all. Your AIS700 does provide the NMEA2000 PGN 129029 (GNSS Position Data) on the NMEA2000 connection. Your GPS position is available on the network but you may need to configure the other equipment to read it. It's also possible that the PGN 129029 is not transmitted by default. You may need to tell the AIS700 to put it on the wire. I did not dig that deeply into the manual.
If you don't have an antenna connected you should get a VSWR alarm. That is normal. If you still get it when the antenna is connected your AIS700 will probably refuse to transmit and your ability to receive will be reduced. Again, I did not read the entire manual but that is the normal response to a high VSWR alarm. Transmitting with a high VSWR can permanently damage the transmitter.
Starscream
Be Free wrote: Fri Mar 29, 2024 7:57 am Congratulations on your new install.
Thanks for that feedback, I think I follow most of it.
When I turned the Autopilot off, the AIS dropped off the network as well. It really seems linked, for some reason. The AIS is on the same breaker as the Axiom display, so they power on at the same time, and the AIS just doesn't show up on the network until I power up the breaker for the autopilot.
I can see in the manual that the GPS position is only available on NMEA0183 at 4,800 baud, which is also the only setting that transmits both position and AIS data. I just don't know how to set that up, and the manual isn't entirely clear to me. It came with a DeviceNet to Seatlk adaptor cable, and this is the only way that I can see to plug into my Raymarine SeaTalkNG backbone. The power cable does have NMEA0183 bare wires, but there's a note that says:
"Note: Whilst it is possible to output both AIS and GNSS data, it is NOT recommended that you output GNSS data to external devices as this can cause data conflicts and / or performance issues. The ability to output GNSS data is intended for diagnostics purposes only"
This suggests to me that I won't be getting a second/backup GPS position signal, and reinforces my intent to eventually install something like a Ray53 VHF that (almost certainly) has a second usable GPS source.
