Interesting test: I used the alcohol stove and CLOSED all hatches. A CO-alarm beeped after a very small time. With open hatch the concentration was low.
26M Alcohol Stove Top
- kurz
Re: 26M Alcohol Stove Top
I just use Alcohol stove in my
- Jimmyt
Nice rig Kurz!kurz wrote: ↑Mon Mar 09, 2020 2:10 pm @ BOAT
here my gimbal alcohol stove... Love it![]()
here the video:
https://drive.google.com/file/d/1a6Vwzu ... sp=sharing
So the spaghetti never geht seasick![]()
I really like the heat shield! Very cool!
- Jimmyt
- Jimmyt
What's wrong with using the lit candle leak detection method? Dog don't cut the mustard? Is that the same as cutting the cheese?Highlander wrote: ↑Wed Mar 11, 2020 11:43 pm That was such B/S phoney test , first off u don,t install an sniffer alarm sensor 4ft or more above the the floor level that,s why it took over 20mins before it sounded an alarmit,s supposed to b installed as close to the lowest level in the bilge as poss. an not too close too batts either , best place in our boats is directly below the galley , on a cold damp day like in that test the gas is going to lay really low in the bilge floor area on a hot dry day it,s gonna fill the whole cabin air with fumes
Boat just think of it as having gas heating unit in the bilge free of charge just waiting on ur source of ignition when required instant heat in a flash on those days when u need it or not !
A good sniffer alarm is the only way to go " a marine unit" not one of those battery house hold one,s , remember it must b ignition protected & ur dog do,nt cut the mustard![]()
u can also go the cheap way buy a little bird cage & put a little canary in it left in the aft berth & when it falls off it,s perch u know it,s time to evacuate the boat![]()
or if u think u may have a gas leak just light up a candle & start lookin for the source of the leak u should find it pretty quick I,m sure![]()
J![]()
You started out all technical, then shifted to stand up. Always a treat!
You may have a point. Candle in the bilge would burn off excess vapors. Brilliant!!!
- Jimmyt
Interesting thought Russ. Burn it off before it accumulates... Not sure it'll work, but hold my beer and watch this!
Running my AC sporadically. Short sleeve Tshirt weather, here in LA (lower Alabama). How are things in Bozeman?
- BOAT
I just use this stuff from home depot - is this stuff okay? (or am I gonna die?)
- kmclemore
Well, given that it says “clean burning fuel for marine stoves” on the bloody label, I think you’re probably good to go.
- BOAT
Okay, well that's good to know. So this is the stuff that is going to blow up the boat.
Would it be better to use the stuff that Highlander drinks? (might be safer). Although, i would not eat any mustard at Highlanders house.
- Jimmyt
well u can always drink the stuff & keep u nice & warm & cosy
like she says can,t u feel it ?
Well another option is to use a heat gun & if u start to get small flames coming from the red hot coils in the tip just keep going in that direction & as the flames get bigger then u know u r getting closer too the source of the leak just make sure u have a long enough extension cord would,nt want u to only git half the job done !
No hydro N/P do the same thing using one of those butane BBQ lighters
but we all know the candle is the way to go if u know for sure u r going to heaven then the candle light will show u the path to go
Just thought I,d mix up a wee bit of tech with some more skillful stand-up Geez u guy,s should b paying me for all this entertainment
PS I already tried the match stick method was an exhilarating hot trip but when I got there
