Hi All!
We apologize for delays in postings.
With no intent to raise ire with those up north but we here in SC have been having some of the most gorgeous and beautiful and warm weather for being out on the water!!!
We have been out on the water 8 of the past 14 days or so with another day at the beach!
This is the Beaufort, SC area where we are doing our Spring 2021 “Sea Trials” with Over Easy:
Here are a couple simplified tracks of the day voyages we’ve made so far:
> Our initial launching from Sam’Point Landing and evening/night-time voyage to Port Royal Marina
> Our general day trip voyages to familiarize our selves with motoring Over Easy and our local estuary environment:
> Our most adventurous voyage yet ( next to our initial launching that is
) where we motored Over Easy out into the ACTUAL ATLANTIC OCEAN past the outermost ICW entrance marker buoy!!!
Fortunately our old limited power Tohatsu has been hanging in there through all these adventures.
Ah, regarding our engine issues.....
With the tell-tale stream now unclogged we have check the engine temperature by feel at various different power settings and find that we can be fairly certain that we are not actually having an actual over-temp issue. (That is not to say that a sensor or something isn’t mucking about though). This is a BIG relief.
Then on our travels on May 20th our Tohatsu decided to do something very very different! It accelerated up to 4000 rpm and was somewhat happy to stay there. This was surprising and unexpected as we have attempted many times to get the engine to go past 2800rpm only to have it balk, kick, sputter,stammer and occasionally just plain quit on us.
We ran it around for about an hour gradually applying power and slowing down. To the best we can describe process worked as follows:
Idle at about 500rpm faultering...then gradual acceleration to 2500 rpm where the engine starts to burble and skip...further throttle movement makes the burbles worse as rpm climbs to 2800 rpm......the throttle lever position is now at the full open position stop....the engine faultering gets worse and then at this point the engine instead of dying( as it has done before) starts to accelerate and then rapidly accelerate to 4000 rpm and stays there! Now granted this is nowhere near the 5000+rpm that should be wide open throttle but this was a definite surprise! After several short term tests of this we had to call it a day due to our tide window to get back into our slip.
The next day we went out and the engine process repeated itself. For the first time since launching in SC we drained the ballast tank while underway. The vessel lifted up and appeared to be making about 14 mph at 4000 rpm. We throttled back to 3300 rpm so as not to push our luck and we’re still making about 10 to 11 mph. So with some trepidation we decided to head out to the Atlantic Ocean to get our feet wet! The weather was perfect, light breeze, bright sun and temperatures in the low 80’s F.
At the edge of Bay Point the head-on swells increased and we slowed down. Refilling the ballast with any headway took over a half hour and even then it wasn’t as full as it had been before. The increase ballast stabilized Over Easy and we continued out at 2500 rpm and about 6 mph.
We followed the Beaufort River out along the ICW route markers to the very last one at the edge of the Atlantic Ocean and then a little bit more to be sure!
at that point we touched the Atlantic and headed home.
All the while the Tohatsu was Stiil following a low idle ... accelerate to 2500-2800 where it starts to baulk ..... then a gradual continued acceleration to 4000 rpm. On the return trip with the swells and full ballast we made about 12 mph. We found that to sustain power level this we needed to be regularly squeezing the primer bulb (in the upright orientation) or the engine woul start to falter and at one point just to see what happened without squeezing the primer bulb the engine quickly decelerated and quit.
Going over the Tohatsu engine troubleshooting matrix we saw that several things could be causing the problems we have been incurring.
> Restricted fuel flow to the engine
> Dirty fuel filter
> Weak fuel pumping
> Carburetors needing rebuild
> Carb floats set too high/low
> etc......
So.....Where to begin.......
Well seeing as the the vessel is on the water in the slip we’re not too keen on fussing with fuel pumps and carburetors so we will stick with our plan to complete our modification of the fuel supply system now that all the ordered items are finally in hand.
> Fuss with the in-tank fuel pickup siphons to get them into the lower corners of each fuel tank
> remove the quick disconnect sprayless fittings and install straight through fittings clamped to larger hoses
> install fuel tank selector valve
> install Fuel demand Valve (pressure regulator)
> install new primer bulb with longer hoses to make it easier to access and use
> install fuel filter/ water separator
> install new line to engine fuel inlet port
We hope to get that accomplished in the next day or two so we can get out Friday to test if it made a difference.
The Journey Continues...Onward
