Honda 50 charging lesson learned, what not to do
Posted: Wed Aug 04, 2004 11:21 pm
by Mark Chamberlain
All the honda 50 owners, here is some information you need to know.
. Keep you ground and postive cables very clean of build up. do not take your battery cable off the engine while it is running. Nor do you want to turn your dual battery switch to off.These actions will cause you to burn up your altenator windings. cost about 110.00. Re quires you to remove fly wheel to replace. If your tach stops working on the honda 50 that means you are not charging the battery. You can tell if you burt the windings by a visaul inspection looking at the windings under the fly wheel after removing the cover. Also the bolts in the fly wheel must be replaced, you are not to reuse the factory bolts. They are a special bolt that must be thrown away once removed.
Mark
http://windmusher.com/img90.jpg[/url]
Re: Honda 50 charging lesson learned, what not to do
Posted: Thu Aug 05, 2004 6:48 am
by Paul S
Mark Chamberlain wrote:All the honda 50 owners, here is some information you need to know.
Mark
I would never think about taking battery power off an engine while it was running, regardless of the vehicle. It can potentially cause havoc on all motors.
Many bolts on engines can not be re-used. Not unusual.
This is one reason I did not install a 1-2-both-none switch. I used 3 separate switches (cluster). 2 stay on all the time, one is a parallel switch. Never ever have to touch them in daily use. Plus the beauty is both batteries charge without touching the switch. It is a win-win. I can think of no reason to use one battery switch to control 2 batteries - too easy to induce user error. One senior moment can cause problems like you experienced.
Picture of the switch - click to enlarge:
Paul
Thanks for the info. Mark
Posted: Thu Aug 05, 2004 5:26 pm
by 26XSunsailrs
I have almost done the same thing several times Mark, sorry it happened to you. I have a Honda 50, so your tach not working symptom is a great tip....... hopefully I will stay lucky and not make the mistake. Thanks for posting, it will help many others!
See you on the water,
-Steve '99 26x
Motor back online
Posted: Sat Aug 07, 2004 7:09 am
by Mark Chamberlain
I just got in the Altenator windis, re
placed them in about 30 min, tack works now and headed out to Valdez Alaska for another week of fishing and just killing time. cost of the ciols was 99.00. a costly lesson learned.
http://windmusher.com/page11.html
Posted: Tue Aug 10, 2004 10:09 am
by kmclemore
Ugh.
I just got back from a week-long trip in my
and my batteries never charged up, despite considerable motor use.
Oh, and my tach doesn't work.
Grrrrrrrrrrrrrrrr.
OK, so where do I get the alternator parts for a Nissan 50?
Sigh.
Posted: Tue Aug 10, 2004 11:41 am
by Don B
Paul,
I'm sure yours works fine ! But IMHO it looks like an arrangment I saw some kids wearing in the last episode of Grid last night.
Please don't take offense it just kinda caught my eye.
-DOn B
Posted: Tue Aug 10, 2004 12:36 pm
by Paul S
Don B wrote:Paul,
-DOn B
I must be getting old. I have no idea what that means.
