Where can we mount our lifesling?
Posted: Fri Mar 20, 2009 11:29 am
by escape
Where on our cockpit or thereabouts can we mount our lifesling in our 2002 MacX? We are green horns still setting up the boat..Thanks in advance.
Re: Where in the cockpit can we mount our lifesling?
Posted: Fri Mar 20, 2009 11:51 am
by Divecoz
We have ours hanging on the Rear Mast Support Over the engine. Up, out of the way and always easy to find :)
Posted: Fri Mar 20, 2009 11:56 am
by tangentair
What model? Does it have the hoist? I would think you would want the sling ring and line back by the aft starboard (to keep it out of the swinging up seat) life lines and the hoist has to attach to the boom - if you use the hoist be sure you attach the topping lift before you drop the main sail and you might want to use at least a 1/4 or 3/8 line for the topping lift.
Posted: Fri Mar 20, 2009 12:29 pm
by Jim Bunnell
I mounted a stainless tube from the rearmost stanchion to the mast carrier arch on both sides (I don't have the extra seats). On the port side I've mounted the barbeque, on the starboard the life-sling, both outboard of the cockpit. No interference with anything, and the bracing makes the mast carrier feel more substantial when climbing up from the stern. Sorry - no pictures, still under winter covers. (Whoops - sorry. I have an M, the original poster an X, so no mast support arch).
