I made my own boarding ladder
Divecoz
Post by Divecoz »
The ladder enables my wife 5'0" to get safely from our dink back into the boat, and vice versus.
Its all of about 25 feet of rope and a total of 10 feet of 2" PVC and another less than 10 feet of 1/2 PVC.
The Bottom Pipe / rung , has drain holes in it and a couple old lead weights to make it sink and yet not add too much weight.
I have about 12" of 1/2 " pvc between ( vertically) teach rung . I drilled a hole at the end of each step in from the end about 1 inch. It took a little trial and error but I can up with the proper amount of rope and now with a large stainless clip on one end and a loop on the other I simply wrap the clip side twice around the pedestal and clip the loop , then toss the ladder over the side and there you have it a mounting / boarding ladder that's easy and safe to use easy to deploy and fairly easy to store when not in use. Cost ? Peanuts maybe $20 Or you can by a rather flimsy unit at W.M. or the like for 2 to 3 times the price.
Inquisitor
Re: I made my own boarding ladder
Post by Inquisitor »
Oh, you can't get off that easy... 8)
we are going to have to have a picture of this.
I have a 5'0" Admiral... and getting from the beach up on the bow is not as easy as it once was for her...
well... for me either.
Divecoz
Post by Divecoz »
Inquisitor wrote:Oh, you can't get off that easy... 8)
I need to learn how to do just that.... post pictures that is. I made quite a few mods this winter and I would like to share them ( brag hahaha ) Best I can do for now is to say. Its a fancy rope ladder with 5 pieces of 2" PVC 2" long for each for step.
The first, bottom most step , has PVC caps on both ends to hold the dive weights inside and vent holes to allow the water to flow in and out quickly. Then I have 1 piece of 1/2 pvc pipe added to the ropes on each side to keep proper separation between the steps and I just keep going up till its as long / goes as deep as you desire. First attempt I had feet on the bottom 2 rungs because of the hull shape and wanting to keep the "ladder " on one plane but found I dont need for the ladder to be that deep into the water. It did entail some trail and error till I got what I wanted.
opie
Post by opie »
Wait a minute. I also have a 5' admiral. What gives? Spooky.....
2BonC
Post by 2BonC »
Divecoz
I think some of us are tense like me to see pictures of Your mods. Why don´t You just sighn in at "photobucket.com". You than uploade Your pics there. Once they are uploaded You just insert the address of the relevant picture (automaticly generated by "photobucket" ) between the underlined part like this
[img]http://i325.photobucket.com/albums/k376 ... ple.jpg%20[/img]. That should work :)
Rainer
Inquisitor
opie wrote:Wait a minute. I also have a 5' admiral. What gives? Spooky.....
Maybe we're just lucky... or better yet... they're lucky.
They don't even have to bend over when they walk around inside. :)
Divecoz
Post by Divecoz »
2BonC wrote:Divecoz
Rainer
I will work on this ( photo bucket site )tonight or tomorrow . I am now going to start a new Topic thread listing the Mods I made on my boat just for my adventure.
I hope the photo site is not as confusing as they were years ago.............
The Mutt
Post by The Mutt »
My wife sounds like an Amazon compared to Divecoz, Inquisitor and opie "Admirals", she stands at 5' 2" :wink: .
While I have to stand below the hatch and almost touch it when closed, my wife walks in without a problem.
Glenn
temall00
Post by temall00 »
Divecoz, Love the ladder!!!
Do the "feet" scratch or did you plug them with something?
Have you tried to get out of water with it or only a dink? Do your feet want to go under the boat?
How much lead weight did you add to the bottom rung, too much, too little?
I'll be working on this one tomorrow... :)
Thanks!!
Tim
CMikey
Post by CMikey »
Try this link for DiveCoz's Mods: http://s325.photobucket.com/albums/k376/2bonc/
DiveCoz,
Did you ever make that trip to Florida this year? If so did you write it up or start a thread somewhere. I would like to read it if one is around somewhere.
Mike
Naples, Fl.
