New trailering mast support for M
Posted: Tue Aug 31, 2004 6:32 am
After trailering our 04 M for a while...Been tired of the mast bending and swaying as I go down the highway. I love the 04 'radar arch' mast support. But the mast has a nasty tendancy to bounce around, especially with the added mass of the rolled up geneoa on top of the mast.
I made a mast support out of layered plywood. I use one of the the mast raising support cables over the top, secured at both sides where it normally would when raising the mast. I had to put a small loop in the cable to make it taught enough.
I just took a piece of 3/4" plywood, cut it into strips, the width the same as the base plate where the mast mounts to, a bit wider than the mast holes and the mast raising holes. I cut them to varying length to form a v shape to keep the mast, more or less, vertical.
I will secure it with the bolts for the mast raiser and the mast itself. My first test I just used deck screws and it worked fine. I then put the mast raiser cable over the top secured at the factory locations.
Much better. Very secure. No bouncing. No bending. No swaying. Best thing is it cost about $15 for the plywood
I went through many different ideas in my head. Maybe using PVC tubing, etc, which probably would have worked fine too. But was worried about the strength of it. But I like working with wood, plywood is very strong, especially laminated.
It is still in the design phase..but the initial model worked flawlessly. Just got to take it apart, glue and screw it back together. Maybe stain/paint/seal it for durability.
I'll take some pictures and post the measurements when I get some time. But wanted to post this while it was fresh in my head.
Not sure if X or early M owners will need this, but it is cool.
If there are any better/different ideas on doing the same thing, let me know. Always looking for a better/cheaper/easier way to do it.
Paul
Paul
