Headroom in the head ...
Posted: Thu Jul 02, 2009 5:52 pm
by MSN-Travelers
Early M's had the removable shelf in the head area. Later M's have a molded fiberglass shelf.
I want to cut out a portion of this shelf so the porta-pot sits at floor level. Is this fiberglass shelf a structural member?
Has anybody else done this already? Got pictures?
Paul
Re: Headroom in the head ...
Posted: Thu Jul 02, 2009 7:53 pm
What shelf are you referring to
Posted: Thu Jul 02, 2009 8:30 pm
by Divecoz
I ass u me he's talking about the raised floor area of the M model in the forward head....... But why ? Into to doing deep leg squats?
I ass u me you'll cut out a section and just drop the floor down a couple inches and re-attach and re-glass ?
Posted: Sun Jul 05, 2009 4:53 am
by rockman
If you modify the hinge position and cut the bottom of the door - you can set it up so that the door swing out over the cushions on the other side - gives you heaps more room to do the business, and you can still use it as it was originally intended - if you want to.
The girls loved this mod....
Posted: Sun Jul 05, 2009 7:18 pm
by James V
I have cut some holes through it to attach the head pump. Thick and not to much room gained at the hull starts to curve at this point. What I have done is put the head on the floor (carefule mounting as the water ballest is just 3/4 inch below the floor) and used the back space to hang cloths. Now my shirts do not look like they came out of a bag.
If no better replys posted soon, call Bill at the factory. He knows his stuff.
Posted: Mon Jul 06, 2009 9:30 am
by Mrs_Skipper
When you get a *little* older you might appreciate the height of the head! Right after we bought our
we changed out the porta pottie to get both additional capacity AND height for, ahem, ease of use.
Posted: Mon Jul 06, 2009 7:32 pm
by Divecoz
Mrs_Skipper wrote:When you get a *little* older you might appreciate the height of the head! Right after we bought our
Unless your a very short in height fellow, I have found its strictly back in and sit....... and if I catch you pooping in my pot......... your off the boat!!
OK grand daughters NOT with standing
Unless we can use the macerator its pee-pee Only!!!
Posted: Tue Jul 07, 2009 7:34 am
by MSN-Travelers
Divecoz wrote:Mrs_Skipper wrote:When you get a *little* older you might appreciate the height of the head! Right after we bought our
I have the larger capacity porta-pot mounted on a platform
and then held in place with heavy duty velcro
Perfect height for me but the admiral is 4'10" on a tall day and we have a 6-year-old as a regular guest. Their feet dangle when seated and it is hard for them to maintain a steady seat when we're sailing.
So ... that is why I was asking about the raised "shelf" that is moulded into the floor. I was thinking I would cut out just enough to allow the porta-pot to be dropped to floor level and then, for cosmetic purposes, re-glass the inner hull area that is exposed. The other alternative is moving the porta-pot off the shelf & down to the floor and doing the door mod. [or maybe a combination of both]
Paul
Posted: Tue Jul 07, 2009 8:37 am
I thought that "shelf" was over the ballast tank. Maybe not, but I'd be careful of what's under it before cutting.
Posted: Tue Jul 07, 2009 8:51 pm
by kkelly5655
I like your shelf idea. I've got the potty but don't want it onboard - someone might use it...
I have passed CPVC conduit beneath that space for wiring to an audio panel above the mirror on a new M. There is room, but I'd consider raising the floor before lowering the shelf. You may be able to velcro in a 3-4" step for the little one, and the kid too.
KK
'08 M
Smith Mountain Lake, Va
Posted: Tue Jul 07, 2009 9:27 pm
by Mrs_Skipper
Divecoz,
I'm wondering how I could survive 3 days on board your boat with the rules you impose! No fruit, oatmeal, or fiber??? Luckily Mr. Skipper is willing to empty our porta potty...
Posted: Wed Jul 08, 2009 8:31 am
by Divecoz
Mrs_Skipper wrote:Divecoz,
Though we spent ( I spent ) 5+ weeks on the hook this past winter and we did use the potty ( Mrs Coz visited for 6 days of my 14 weeks) and the macerator pump ..... But when we have guest, its at the Marina where there are numerous potties and showers etc etc.
As for The Admiral Using as needed ?? I have never ever denied access to The One....... Truly in Charge of the Purse!
Posted: Wed Jul 08, 2009 10:51 am
by waternwaves
Dive ,MRS. skipper and others......
I was wondering..... since I have an X, what about a flip down hinged footrest for the shorter set? We have an electric head that I would love to raise, but the shorter legged really young set like the not too high setting.
Or maybe I should put another smaller stepstool like I have on the hunter? I like the easy cleaning of the head with out having alot on the floor, Has anyone tried raising and using a plain stepstool, sail 6 to 8 inches tall?
and the real question, where would I hang it then when not in use??
thanks
Posted: Wed Jul 08, 2009 4:51 pm
by Divecoz
A folding step sounds good to me for the short folks /kiddies. Maybe along the lines of a fold and lock camper step??
Not in your way and easy enough for them to drop and to LIFT!! when they are done... Ouch Oooh dang who left that down again ???
