Trailer wiring urgent
Sea Dreamer
Post by Sea Dreamer »
Sitting on I295 outside richmond, va. need to wire new plug for trailer. Does anyone know off top of head which color wire does what?
Hamin' X
Re: Trailer wiring urgent
Post by Hamin' X »
I just went out and checked my 2001 trailer.
White = Ground
Green/Brown and Yellow/Brown = Tail Lights
Yellow = Left Turn
Green = Right Turn
Brake Lights are combined with turn lights.
Separate White Wire is brake solenoid lockout.
Hope this helps.
Sea Dreamer
Rich: Found an earlier post referring to a wiring website diagram, and that seems to match up to what we have. We don't have a yellow/brown and a green/brown - just solid yellow, solid green and solid brown. Sound right to you? Thanks!
Hamin' X
Post by Hamin' X »
The soilid brown must be split afterwards on yours and go to the separate tail lights. Good luck.
School House Steve
Location: Milton-Freewater, Oregon 2007 M, 50 HP Merc, "Comfortably Numb"
Post by School House Steve »
Hammin X is correct. If you also have the surge brake system the fifth wire should be blue connected to your back up lights to disable your brakes when backing up.
SS
bubba
Post by bubba »
school house Steve I thought you droped of the screen. You forgot to say - If you do not have a plug for the extra backup light put a nut from a bolt in the slot where the breaks slide and you can back up without any wiring, just hook it up if driving down the road.
School House Steve
Bubba,
I did drop off the screen. My Computer got a virus this summer and I had to start from scratch again. Meanwhile I've sailing as much as possible and installed several mods this year. I was out the same weekend as you and Hammin X but in the upper part of lake Wallua so I could tune my new HD TV to the local Tri-City stations.
Steve
Post by Kelly Hanson East »
:D :D
