What did they do wrong?
2BonC
Post by 2BonC »
Image :o
...they have forgotten to remove the bumper with the backlights...
Rainer
Re: What did they wrong?
Here's a thread that talks about this incident. The Mac in background belongs to a board member.
aya16 wrote:wow small world Look closer thats my whaler with Karen in blue holding it at the dock, next to the mac. What happened to the guy launching, He just bought that used whaler never launched a boat before and backing it in he hit the gas instead of the brake, the truck floated some to the side and once sunk proceeded into the bottom of the ramp where it ends. The truck was completely submerged going the wrong way, it took the whaler strapped to the trailer down with it. The owner dived down and attached the tow truck cable to the whaler trailer, and was pulled out backwards. You can see the cable attached to the tow truck.
Worse part of it all for the guy that did this, was the fact the truck was borrowed from a friend, it wasnt his.....
Mike
bubba
Post by bubba »
Seams like I have seen this photo on here before.
KayakDan
Post by KayakDan »
This is a photo of the Ford F-150 with the "Submersible Towing Package".
:D
KayakDan
Post by KayakDan »
Or...
"Ya might wanna think about bottom painting it if ya plan to leave it in for a while..."
Post by Kelly Hanson East »
Fast white body/ hull... :D
I think he missed the Ferry !! :D
Scott
Post by Scott »
His GPS hadnt updated since the dam back filled.
"The road used to be here"
40Toes
Location: St. John's, Newfoundland, Ontario 28 - Formerly 2000 26X
Post by 40Toes »
Nothing. Basically this is a techinque used in warmer waters, you simply drive straight in until the boat floats free and pull a U-Turn and drive straight out. Of course this only works on wide ramps and you have to make sure your windows are all the way up or you may get wet!
bubba
Post by bubba »
One too many beers or shots
Scott wrote:His GPS hadnt updated since the dam back filled.
http://www.youtube.com/watch?v=0yyKrS8jwSY
The machine knows.
ALX357
Post by ALX357 »
How did the truck get nose-in ? The explanation says he gassed it instead of braking, ? so he was just approaching the ramp before he turned around, .... ?? This is funny but doesn't make any sense to me.
Hamin' X
Post by Hamin' X »
He was backing down the ramp and gassed it. Both the boat and pickup ended up in the water and since the boat and trailer were floating and the pickup was sinking, the rig pivoted around. The tow truck hooked onto the boat trailer to pull them both out, thus straightening things out, but backwards. At least that's how I understand it.
Flash916
Re: What did they do wrong?
Post by Flash916 »
They went to the wrong boat ramp, they needed the one with the water on the other end.
Scott
Post by Scott »
Must be in Australia. After all the water in the crapper swirls the wrong way down there.
Hey Aussie Groupsters, is the water on your boat ramps down there on that end?
Crikey!!!
