Need new wheel rims
Posted: Thu Jan 14, 2010 5:27 am
by BrazDaz
Hi guys
I did see a link to a web site with Mac trailer rims, but cant seem to find it now. your help would be greatly appreciated.
thanks Darren
Re: Need new wheel rims
Posted: Thu Jan 14, 2010 6:43 am
by Paulieb
I've seen trailer tires exactly like our Mac's mounted on rims that look identical at Wal-Mart.
Sorry, don't know the price, and I am not sure if you can just get the rims, but worth a check.
I am sure someone else will have a better answer shortly.
Mine are pretty badly rusted, so I was thinking about replacing as well.
Paulieb
Posted: Thu Jan 14, 2010 12:27 pm
by Kelly Hanson East
Ive found buying the mounted tires online is the same price as buying the tires (without rims) locally....go figure.
Posted: Thu Jan 14, 2010 1:11 pm
by Scott
Any trailer store/ builder / seller will have the rims ands tires.
I got the ones I used when I did the dual axle mod for $14. ea for the tire and rim. Mounted.
Posted: Thu Jan 14, 2010 2:36 pm
by MadMacX
I would think that shipping wheels and tires Down Under would be quite expensive. The wheels are nothing special, they are just a Ford 5 lug 4 1/2" bolt pattern and if IIRC they are 14" x 5 1/2". I would think that you could probably find something similar over there. If not, I purchased a couple from these guys a few years ago. Don't know if they export, but....
http://www.lowcosttrailersupplies.com/M ... S/CTGY/WSW (Disclaimer-I have nothing to do with these guys!!
) Or, try here
http://www.championtrailers.com/ (Again, I have nothing to do with them, either
If you are buying new tires and wheels, I'd check and see if you could use 15" wheel/tire combination to increase the load carrying capacity or at least go with the 225 tire. Again it will add a little bit of extra carrying capacity, not a large amount, but with a Mac trailer, every little bit helps.
Good luck,
Pat
Posted: Fri Jan 15, 2010 1:28 am
by denisesjoy
Some one suggested to me that they were Nissan Navara wheels!
Posted: Sun Jan 17, 2010 7:59 am
by jaguar496
We have an
. Had a new tire(225-D rating) ordered and mounted on the proper wheel from our local tire shop. our cost was $75.00 US.
Both tires give a 5500lb carrying load. stew
Posted: Thu Jun 03, 2010 6:13 am
by BrazDaz
Hi Guys
Finally got a new rim for the 06 steel MacGregor trailer. Its straight of a Big hub Ford 1 tonne Utility.
Made in Australia the quality is much better than the original equipment. $89
Cheers Darren.
Posted: Fri Jun 04, 2010 3:01 am
by trip01
Darren,
I need to buy new tyres however, the best load index available in Aus currently for a 225/75 15" is 112. Not enough. Am looking for a 116 with 10 ply walls.
http://www.bobjane.com.au/load-speed-ratings.html
The OEM's are approx 113 Load Index. Had a blow out on these.
In the mean time I'd like to purchase a 2nd hand Ford rim & std tyre of 15" x 6" in the 114.3 stud pattern. (to get us out of trouble)
I am not sure of the offset though. Any idea of the offset from your experience. Where to buy such a rim from also ?
Kind Rgds
on 08 Alloy trailer
Posted: Fri Jun 04, 2010 3:48 am
Thread warning - tire and rim sizes are not internationally standard, so be careful with designations of sizes that cross borders...
Posted: Fri Jun 04, 2010 4:37 am
by rwmiller56
I bought new tires mounted on rims from Trailer Parts Superstore / Eastern Marine. They also sell the rim only. Price was not bad:
http://www.easternmarine.com/shop/
Roger
Posted: Thu Jul 08, 2010 6:43 am
by BrazDaz
Hi Dave
My rim was purchased from Swan Tyres in Perth its a 15X7 Mullins Description on invoice is 5x114.3 et10p $81.82 +gst = 90bucks..
It appears to have a 10mm positive off set, the bolt face is 10mm closer to the front face of the wheel than the rear face. I hope this helps
Cheers Darrren.
