6 Headsail Running Rigging Configuration
Posted: Wed May 05, 2010 8:29 am
I see some guy's are finnally seeing the advantage of running multipal headsails that I have been doing for quite a while now. So for those who would like to do this mod I've already done alot of the design concept not completed yet , this plans shows the routes for running the sheets !
Still not shown here are the plans for the outriggers to control the 6ft bowsprit pole extension guy control lines & rope clutches & swivel & fixed power cleats , deck organizers these will have to go onto another page to be readable
Also not shown design plans for masthead swivel adj, sliding backstay on a traveller to support all these rags has been completed & installed
Progress for now inner storm sail forestay deck fitting installed ,
7ft Genny tracks installation in progress I have changed the design plans three times now & finnaly happy with the design had to be simple so as anyone can make this mod at a very reasonable price .
6ft Cruising Spinnaker ext pole made but still working on mounting brkt I was not satisfied with what I thought would work now working on a new mounting brkt concept !
#7 Lewmar aft winches should be installed this wk-end along with mainsheet traveler 2.1 conversion which I copied from some of the guy's on this site Thx !
once I figure I'm done drilling holes in the deck & cabin roof then she will come out of the shop for a mast raising then alot of new coloured sheets to run hope I did all my calgulations right these line sheets are not cheap !
Well must go now trying to chase down some 3"x 6" x 1/4" Alum Angle !!
http://i844.photobucket.com/albums/ab1/ ... r/scan.jpg
