Centerboard trunk
Posted: Sat Dec 25, 2010 5:29 am
by Ixneigh
Has anyone actually broken the centerboard trunk on one of the early ventures? Mine seems to flex quite a bit even after installing an extra brace. Or maybe its the hull or the rest of the boat flexing.
Re: Centerboard trunk
Posted: Sat Dec 25, 2010 4:13 pm
by Lloyd Franks
Is the centerboard flexing? Not the trunk I hope.
Posted: Sat Dec 25, 2010 6:55 pm
by Ixneigh
Yep the top of the trunk moves visibly while sailing.
Posted: Wed Dec 29, 2010 2:22 am
Yikes...can you snap a pic and post..better yet a movie clip?
Posted: Wed Dec 29, 2010 9:54 pm
by K9Kampers
It's possible that your centerboard trunk is the center of the universe, and everything else is moving in relation to it! :wink:
Posted: Thu Dec 30, 2010 7:09 am
by ChockFullOnuts22
How is the bottom of the hull around the trunk? Any problems with blisters, cracks, or past repairs? Hopefully you're not getting leakage into the hull/trunk core.
Posted: Thu Dec 30, 2010 9:03 am
by capncarp
I assume you are talking about an X since it has a centerboard and an M has a dagger board. I don't know how it is possisle for you to be able to see the trunk move while sailing. The C/B hanges on a hanger and only makes contact with an small, strong part of the hull. If the C/B is moving it would also be making alot of bumping noise.
capncarp, :macx:
Posted: Wed Jan 05, 2011 3:49 pm
by Ixneigh
No she's an older venture 22. It does not flex a lot but does visiblly move. I was just wondering if the trunks on these boats had known issues.
Posted: Wed Jan 05, 2011 4:53 pm
by Lloyd Franks
I have never heard of a venture 22 or 222 having issues with the trunk housing. They were built like tanks. A picture would be helpful, as would your responses to questions in the above posts.
Posted: Sun Jan 09, 2011 8:39 am
by Hamin' X
 ! Moderator Note:
Folks, please update your profiles to reflect the boat that you own. The responses to your questions will be quicker and more to the point.
~Rich---Hamin' X~
Posted: Wed Jan 12, 2011 1:54 pm
by cookwithgas
Lloyd Franks wrote:I have never heard of a venture 22 or 222 having issues with the trunk housing. They were built like tanks. A picture would be helpful, as would your responses to questions in the above posts.
Mine is built like a tank. :)
Posted: Tue Jan 25, 2011 5:42 pm
by Ixneigh
Hi again. No the trunk does not leak and although it has a hole in it from where it got hit by lightning it is above the waterline. It is possible that heh heh it is the " center of the universe" and the rest of the boat is moving around it. the whole boat seems pretty flexible. The unusual rig I have on it is probably straining the deck and causing the boat to flex also. But ever since I got the boat ten years ago I had always wondered if anyone had damaged one just by sailing it hard. I've also whacked the bottom pretty hard shooting the shoals under sail but so far have not damaged the centerboard pin.
If I do not upgrade to a larger boat I plan an extensive fiberglass party strengthen and stiffen the boat to better carry the rig loads. Last week after sailing in windy weather the cabin doors where binding in thier frames.
