Starter solenoid
Posted: Wed Mar 23, 2011 1:49 pm
Hi, Our starter solenoid is sticking after starting, getting fed up of lifting the engine cover and tapping the solenoid with the winch handle...... had a look online and only found one company in the UK that quoted £115 +vat, seems steep for a relay, the US list them at $60 but they don't ship outside the USA.
Does anyone know of a good UK Mercury dealer / Canada Mercury dealer (Got a friend in Canada )or can anyone advise a similar replacement from another manufacturer, the part no is 825096T01 for mercury.
Unless I'm missing something the solenoid is just a low voltage low amp coil that energizes a plunger to make contact with a low voltage high amp starter current, as long as it is rated for the switched current it should work right .
ta
ta
