Hello Y'all,
Could someone measure the distance on a X model from the outside of the stern rail to the outside of the other stern rail for me, Please? I really need the dimension tonight if possible. Thanks, Tony
Urgent X dimension needed ASAP
briggs
- Location: Cleveland, OH Forest City Yacht Club 2000x Yamaha 50 4 stroke
Re: Urgent X dimension needed ASAP
I measured 81 3/4" across the top and 69 3/4" at the bottom in the dark alone not sure what it is in the light with company. Mine is a 2000 by-the-way. Hope that helps.
- TonyHouk
- Location: My New Hometown, Fort Mill, S.c. "98 X with a '95 Evinrude 115
Mr. Briggs,
Thank you very much. Now I just need to make sure that I had the tubing cut to the right dimensions. Thanks again, Tony
- TonyHouk
I am finally getting around to making the rear arch so that I can get rid of the center mast pole. I want to be able to have the full enclosure up and still sail. There is a place in south jersey that has cheap metal compared to charleston. So it worked out that I was able to visit my parents and get the tubing. Did you ever get the motor worked out or did you just settle with it?
- Gazmn
Pretty much settled
Am too busy with other things right now - same as last year - & the years before...
