Urgent X dimension needed ASAP
Posted: Fri May 27, 2011 5:58 pm
by TonyHouk
Hello Y'all,
Could someone measure the distance on a X model from the outside of the stern rail to the outside of the other stern rail for me, Please? I really need the dimension tonight if possible. Thanks, Tony
Re: Urgent X dimension needed ASAP
Posted: Fri May 27, 2011 6:55 pm
by briggs
I measured 81 3/4" across the top and 69 3/4" at the bottom in the dark alone not sure what it is in the light with company. Mine is a 2000 by-the-way. Hope that helps.
Posted: Fri May 27, 2011 7:10 pm
by TonyHouk
Mr. Briggs,
Thank you very much. Now I just need to make sure that I had the tubing cut to the right dimensions. Thanks again, Tony
Posted: Fri May 27, 2011 8:46 pm
by Gazmn
Alright Tony...
What are you up to?
Posted: Sat May 28, 2011 3:19 am
by TonyHouk
I am finally getting around to making the rear arch so that I can get rid of the center mast pole. I want to be able to have the full enclosure up and still sail. There is a place in south jersey that has cheap metal compared to charleston. So it worked out that I was able to visit my parents and get the tubing. Did you ever get the motor worked out or did you just settle with it?
Posted: Sat May 28, 2011 5:05 am
by Gazmn
Pretty much settled
Am too busy with other things right now - same as last year - & the years before...
