Shroud covers
Posted: Wed Jul 27, 2011 6:36 pm
by vulcan98
Looked under modified section for these, but could not found any. In some photos I have seen tubes covering your shroud adjusters. PO used 3/4" vinyl tubing. This worked but does not look neat. I found some turnbuckle boots online, but would these work on our chain-plates? Anyone have an idea. Thanks.
Derwin
Re: Shroud covers
Posted: Wed Jul 27, 2011 7:28 pm
by bscott
WM has tubes/caps that work--they are also useful when rigging as they keep my turnbuckles from fouling.
Bob
Re: Shroud covers
Posted: Thu Jul 28, 2011 3:24 am
by 40Toes
The PO put on what I assume to be removable chafe guards (with velco) - they work well.
Re: Shroud covers
Posted: Thu Jul 28, 2011 7:01 am
by Tomfoolery
My :macx: has pvc tubes and caps with slits over the adjusters. They work ok, but they tend to jamb against each other when putting the mast up, and it's not easy to reach down there from the deck to pull them up while the mast is raised. I'm curious myself as to what others are doing.
Not a good pic, but it's all I have showing the covers in use.
Re: Shroud covers
Posted: Thu Jul 28, 2011 9:38 am
by Jim Bunnell
I just use some inexpensive clear flexible tubing from the plumbing department at Lowe's. Slips over the chainplates and is flexible enough that there isn't a problem when raising the mast. Looks good for several years, and cheap and easy to replace when it doesn't. Not a "yachty" solution. but effective.
http://tinyurl.com/3oh9mz8
Re: Shroud covers
Posted: Thu Jul 28, 2011 5:16 pm
by vulcan98
Mine has the same tubing as Jim Bunnell. During the mast raising process my shroud wire would twist at the tang when I took the tubing off, so the PO had a good idea. After a year or two the interior of the tubing would mildew and not easy to clean. Guess I'll try the shroud boot and cap from Davis Instruments. I don't know for sure if these will keep them from twisting. Thanks for every ones helpful advice. Great people and site. 8)
Derwin
Re: Shroud covers
Posted: Mon Aug 01, 2011 6:46 pm
by ronacarme
Thin wall plastic pipe. Cut a longitudinal slit in the pipe to radially receive the shroud wire, or disconnect the adjuster from the hull and slide the pipe thereon axially.
Ron
