Discolouration on coach roof & cockpit floor
Posted: Sun Aug 28, 2011 7:08 am
by robbiebull
Has anyone come across rust discolouration on the coach roof or cockpit floor, I have a 2000 Mac 26X, I have tried to polish them out to no avail
Re: Discolouration on coach roof & cockpit floor
Posted: Sun Aug 28, 2011 12:18 pm
by mastreb
Sounds like a job for Borax :D
Posted: Sun Aug 28, 2011 2:43 pm
by bscott
Try CLR. I also use white wall tire cleaner on the black spots.
Bob
Posted: Tue Aug 30, 2011 1:39 pm
by robbiebull
Borax, you will need to elaborate ?
CLR, again I must be slow this week :P
Posted: Tue Aug 30, 2011 2:05 pm
by Crikey
What about TSP?
Posted: Tue Aug 30, 2011 2:58 pm
by RobertB
Rust stains probably need to be removed with a iron/rust removal product - suggest using IronOut. This is a weak acid, uses include cleaning the resin bed in my house water softener - leads me to believe that if careful and wax afterward, should be OK with fiberglass.
Posted: Tue Aug 30, 2011 8:09 pm
by nedmiller
Leaves and such that might spend some time on your boat may leave some brown staining--our oak trees leave a dark and difficult to remove stain due to tannin. We use Chlorox Clean up--which is a cleaner that has bleach in it. It works really well. Make sure the boat is in the shade on a cool day or morning... spray on and let sit for a while before washing with high pressure. I use a gas powered water blaster. (Keep chlorine products away from electrical connections and electronics.)
SILK :macx:
Posted: Wed Aug 31, 2011 1:32 pm
by Default User
mastreb wrote:Sounds like a job for Borax :D
I bought some 20 Mule team Borax last night based on your testimony! :D
