I have a new 12-gal tank and I have taken the fuel sender off of my old tank and am installing it on my new fuel tank. The unit includes a rubber/plastic gasket that sits over the hole drilled in the top of the tank.
The hole is about 1.75 inches in diameter. Above this hole sits the gasket which is probably 2.5 inches in diameter. This gasket has 5 holes where the self tapping screws go to secure the unit to the tank. Above this gasket sits the top of the sender unit and it has the same holes in its plate for the screws.
I don't have the instructions for this sender unit but it seems to me that when it was installed the first time by the original owner there was some sort of sealant when it was installed. There is residue of the sealant on the gasket.
Does anyone have any idea what type of sealant may be appropriate to seal this gasket to the tank and probably between the gasket and the sender unit?
On Edit: Adding some pics:
Here is a pic of the broken filler neck on my original tank (6 year old tank)
This shows where the fuel line runs under the cockpit...between cockpit and inner line. Electrical line is the cable between fuel sender and fuel gauge on pedestal.
And here is the new tank and you can see the gasket (leaning on the sanding block) and the fuel sender.
