Can I use a water hose? Compressed air?
I dont want to make the problem worse with my "common sense" fixes
Rich
Ran into that. It is dumb. Fishing out a clog is almost impossible. Pressure or suction is the only solution other than changing to a "y". Good idea. I bet it would dramatically reduce clogs as well as making them easier to solve.jbousquin wrote:On my, the problem seems to be the T fitting that ties the sink and transom drain together, underneath the back (port) corner of the rear bed. Any first year plumbing apprentice will tell you that 90 degree angles in drains are not a good idea. I've had mine clog up at that point several times, especially from leaves, dog hair and other debris that gets washed down the engine well drain, and have cleared it using the hose method aimed directly into the engine well drain hole. I like bscott's idea of the river rock in place over the drain hole to keep debris from entering in the first place.
In an attempt to more permanently address the issue on my boat, I picked up a true Y connector from the sprinkler section at Home Depot. I haven't had a chance to connect it and confirm that it fits yet, when I do I'll take photos, post and report.
