Interesting point re: sailing speed
Ran across a nice blurb about sailing speed (something that many of us obsess about) that helps me understand what I can expect when a 41' Beneteau blows past me. 8)
"based on the standard calculation used, in order to get 6 knots you need at least 25 feet of waterline. Since length overall is usually longer than waterline you're probably looking at 27+/- feet to get that."
http://www.sailnet.com/forums/boat-revi ... lue-3.html
reastmure
Re: Interesting point re: sailing speed
Post by reastmure »
Don't know what they meant by 'the standard calculation' but I get my M up to 6 kts plus under sail given enough wind and the right angle, trimed sails . Was pushing 7 the other day. Unless my new GPS is lying. :o
ROAD Soldier
Post by ROAD Soldier »
reastmure wrote:Don't know what they meant by 'the standard calculation' but I get my M up to 6 kts plus under sail given enough wind and the right angle, trimed sails . Was pushing 7 the other day. Unless my new GPS is lying. :o
Nope you are not lying. Once again this same old tired argument comes up about what some forum, book, sailing magazine, and/or engineer says or reads about sailboat and how it applies to a MAC. I am so tired of explaining this so I am just going to make it simple as I can. It comes down to this are you going to believe what you read or what you see.
http://www.youtube.com/watch?v=hQaq0c6Bvoc
Not even close to being my fastest day but is one I have on video :wink:
Québec 1
Post by Québec 1 »
THE CUSCUS
Post by THE CUSCUS »
Your GPS is giving you your speed over land. If you are on the water and going with the current, then the Gps will show boat speed and current combined.
Divecoz
Post by Divecoz »
among other issues is Planing hull versus displacement hull we have a planing hull I among MANY others have broken 8 knots in moderate winds..
That old math is just that.......... OLD Math.. Add among other things Square Headed sails.. Rotating Mast... Canted daggerboards and as I said no less than a ZILLION New Math Attributes.. blablablabla..
Under normal sailing conditions, the Mac is limited to hull speed as the rules generally apply. With our high freeboard, it doesn't point very well either.
With that said, we do have some advantages being a semi flat bottom boat. Going downwind, we can get up on semi-plane and defeat the hull speed rules. A couple of weeks ago we were pushing 7.2 downwind (through the water as we have no currents on a lake). We totally blew past displacement keelboats.
Boblee
Post by Boblee »
Yeah had that you could count on one hand the number of times I have tried to race someone for various reasons but did catch up and almost passed another "real" sailboat down at the Gippsland lakes a few years ago and would have passed him but could see him freaking out at being passed by a :macm: so when he pulled across me just wandered away but point made. :D
Had the :macm: up to 21 kph whatever that is in knots but did have the motor idling for steerage as it was a pretty hairy narrow passage with plenty of rocks with a good current and only a jib flying in the Cambridge Gulf W.A.
Lieu Daze
Post by Lieu Daze »
Seen many posts on the subject but short form of what I understand....
True displacement hulls, full keel standard sloop, have a terminal hull speed of 1.34 times the square root of the length of the waterline. If your Mac had a displacement hull it's terminal hull speed would be 1.34 x sq rt (23.16) = 6.45 knots.
The terminal hull speed of a displacement hull is exactly that...terminal, meaning even if you put a jet engine on the back it just builds a bigger pressure wave up front and still only does say 6.96 for a 27 footer, (at WL).
Because you can get your Mac up past what would be it's terminal hull speed easily with the motor means your riding a semi-displacement hull. So if your riding light, (with full ballast for at least your own souls sake please), reefed on a beam, your pals hiking' out with their wives on their shoulders, you can expect to pass many low 30' ers at approaching 8 knots or a touch above with with only the drag of your smile holding you back.
Best speed on mine was just after purchase, (super light not even a drink holder on yet), without much of a clue how to properly trim, and we hit just over 7.5. It won't be that light again so happy when we get a 7 out of it.
Some of us have change the format so to say
http://s844.photobucket.com/albums/ab1/ ... 010091.mp4
This should never have happened but it did maybe he was a lousy skipper :D :D :D anyway we caught up with him & passed him he was pi$$ to say the least & did all kinda manuvers to try & keep us from passing him :)
http://s844.photobucket.com/albums/ab1/ ... 010090.mp4
Mac26Mpaul
Post by Mac26Mpaul »
Hey Bob,
We had very similar happen on the weekend. We were running up the channel under main alone and there was a keeler under Genny alone. For some reason it had a tinnie tied along side. We sailed past them doing a bit under 5 knots from memory. There was a group of youngish type fellas who were quite clearly having a laugh at being passed by one of those horrible Macgregors :D Five minutes later, the tinnie was off and moving along next to them, and they put up some more sail, I guess it was time to show me my place! Although I am not a racing type, I just couldnt help but unroll the jib. Only problem I could only get it about 80 percent out as there was a bind up there for a few minutes. It didnt matter, because we still pulled away from them. I had 6.3 knots on the GPS and I was towing a fibreglass dingy. It was fun blowing them a kiss as I pulled away :D Got some video too :D
Very nicely put. 8)
Lieu Daze wrote:Seen many posts on the subject but short form of what I understand....
Your video is showing MPH. 7.5 MPH, which is 6.5 knots, which is the theoretical hull speed for a MacGregor. That said, unlike a normal displacement hull, it is possible for MacGregors to get up on a plane, even slightly, under sail and perform better than maximum theoretical hull speed in downwind conditions.
ROAD Soldier
mastreb wrote:Your video is showing MPH. 7.5 MPH, which is 6.5 knots, which is the theoretical hull speed for a MacGregor. That said, unlike a normal displacement hull, it is possible for MacGregors to get up on a plane, even slightly, under sail and perform better than maximum theoretical hull speed in downwind conditions.
Obviously you didn't see the whole video I was hitting 8.1 MPH and also wrote that is not my fastest speed either, not even close to be exact. Also one more thing that I didn't mention is that the lower Potomac is a tidal river and guess what direction it was going in that video? If you said with me you would be 100% wrong :) .
Sweet! I've seen video up to 10.9 knots on a Mac, so clearly planing is going on. You were going downwind, correct?
