MoTor won't turn over. Ran yesterday. Etec 60
Posted: Tue Sep 11, 2012 6:49 am
by Ixneigh
Hi everyone. There was something like this on the board before I think.
I have tilt, beep on key turn. Nothing else. Batteries light lights fine. Ive tried start on dead batteries. Nothing like this I checked the ten amp fuse on the plastic flywheel shroud. Any other fuses?Mean time I shall try rowing the yacht since its flat calm. :D :D
Re: MoTor won't turn over. Ran yesterday. Etec 60
Posted: Tue Sep 11, 2012 6:55 am
by K9Kampers
Are you in nuetral? Try working the shift handle F-R and back to find N.
Posted: Tue Sep 11, 2012 7:09 am
by Ixneigh
Got it. Tried that and thought it was in position. First thing I looked at. Did the full arc of motion and it started. 8)
Posted: Tue Sep 11, 2012 7:11 am
by Bassco66
Hi from tassie
I agree with last post, check for neutral. Easy mistake to make. :macm: :D 8)
Posted: Tue Sep 11, 2012 7:36 am
by raycarlson
first check batteries and connections,your lights can work fine but starter won't crank if your down to like 12.2-3volts, and most important make sure you are using XD-100, i hear it's like a magic potion for ETEC's
Posted: Tue Sep 11, 2012 9:20 am
by bscott
Another common problem with E-tec is the throttle cable coming off at the engine and the neutral switch not activated.
Also, BRP does not recommend wing nut battery connections--not sure why but they don't. My engine has started with less than 12v. and with one manual turn of the flywheel.
Bob
Posted: Tue Sep 11, 2012 10:35 am
:D :D :D :D
Youse just plain NASTY, Ray !!!
:D :D :D
Posted: Tue Sep 11, 2012 1:30 pm
by Hugh
And I thought it was just me. The shifter/throttle lever may be stiff when new. We've only been out 2x but finding neutral is tough. I find I have to watch that the movable part of the lever slides down to engage neutral. My second attempt at docking I reversed the motor, shifted into what thought I was in neutral, I jumped out with the stern line. The boat started backwards. :| luckily my wife had secured the bow. I scrambled gracefully back into the cockpit to find neutral.
I hope no one at the ramp noticed....
Hugh
Posted: Tue Sep 11, 2012 1:55 pm
by March
Classic.
Did you put it in neutral when you started rowing?
Posted: Tue Sep 11, 2012 2:24 pm
by K9Kampers
Hugh wrote:... The boat started backwards. :| luckily my wife had secured the bow. I scrambled gracefully back into the cockpit to find neutral.
I saw that maneuver on a YouTube vid... was that youuu?!! :D :wink:
